Maximum spring compression problem
In summary, the problem involves a 7.0kg box moving at 6.0m/s on a horizontal, frictionless surface colliding with a spring of force constant 50N/cm. The maximum compression of the spring can be calculated by finding the amount of work done by the box, which is equivalent to its kinetic energy. This energy is then transferred to the spring as potential energy, which can be expressed as P=1/2kx^2. By solving for x, the maximum compression of the spring is found to be 22.45cm.
whdahl
A 7.0kg box moving at 6.0m/s on a horizontal, frictionless surface runs into a light spring of force constant 50N/cm .
What is the maximum compression of the spring?
K=1/2mv^2
K=1/2(7.0)(6)^2 = 126N
126N/(50N/cm) = 2.52cm
That is apparently incorrect.
K=1/2(7.0)(6)^2 = 126 Joules not Newtons
2. Homework Equations
K=1/2mv^2
What type of equation is this? Moment, energy, work? This will refer to the equation used fr the spring. Your equation you use for the spring part is incorrect that is why your displacement will be inccorect...
It is a work problem
Once again, think it in terms of energy. What happens to the kinetic energy of the box if energy is conserved?
Okay so what amount of work(kinetic energy) can be done by the box? Use your equation and do exactly the same, just get your unit correct for work/energy.
What do you think happens to all this energy once the box comes to a momentarily stop? Energy cannot get created or destroyed it can only be tranfered from one form to another... So if there is no kinetic energy in the box, and the system is at a standstill, where is all the potential energy stored?
The kinetic energy from the box is then stored as spring potential energy P=1/2kx^2. I think I see my problem. I have the final equation:
126J=126Nm=1/2(50N/cm)x^2
25200Ncm=50(N/cm)x^2
x^2=504cm
x=22.45cm
Thank you guys, you helped a lot!
pleasure, great job by the way...
FAQ: Maximum spring compression problem
1. What is the maximum spring compression problem?
The maximum spring compression problem involves determining the maximum distance a spring can be compressed before it reaches its elastic limit and can no longer spring back to its original length.
2. What factors affect the maximum spring compression?
The maximum spring compression is affected by the material and thickness of the spring, the amount of force applied, and the spring's initial length and tension.
3. How can the maximum spring compression be calculated?
The maximum spring compression can be calculated using Hooke's law, which states that the force applied to a spring is directly proportional to the distance it is compressed. By knowing the force applied and the spring's spring constant, the maximum compression can be determined.
4. Why is it important to consider the maximum spring compression?
It is important to consider the maximum spring compression to ensure that the spring is not compressed beyond its elastic limit, which can cause permanent damage to the spring and affect its performance. It is also important to determine the maximum compression to ensure that the spring is suitable for the intended use.
5. How can the maximum spring compression problem be solved in real-world applications?
In real-world applications, the maximum spring compression problem can be solved by conducting experiments to determine the maximum compression of the spring under different conditions. Computer simulations can also be used to accurately predict the maximum compression of a spring. Additionally, manufacturers often provide specifications for their springs that include the maximum compression limit.
