Maximum suction force in a suction cup
In summary, an expert summarizer found that the two models have different abilities to stick to a flexible surface. The ring model with 8 holes is better at applying pressure and has a larger area.
teunKeusters
Sorry if I didn't post this at the right place.
Hi all,
I have a problem that I am not able to solve. I hope you guys can help me! I am creating a suction cup to grab and lift an object with a flexible surface made of out silicone The suction cup is also made out of some sort of flexible material (not sure which yet).
I currently am considering two different models, both circular, but one is a ring, while the other one is more like a disk. Both models contain 8 holes in the top surface to create a vacuum. A cross-section of both:
My question is: Which of the two models will stuck the best to the flexible surface, considering you are using the same pump. And which parameters are important for this question?
My reasoning so far:
On first instance you would expect the suction cup with the largest surface to pull with the largest force. However, when the silicone surface is sucked into the cup it will block the air holes. This probably limits the surface area to the surface of the 8 holes. My gut feeling is that more pressure is needed to make the silicone reach the top of the model in the ring model, but perhaps that is just nonsense.
I hope you guys can help me making sense of the choice I will eventually make. I tried to ask this question as clear as possible, but I have trouble formulating it, so if anything is unclear, pleas ask me.
Thanks in advance guys!
Interesting problem. But there should be two questions. How much suction can you apply? How much time does it take to achieve max suction? The second question is related to the number of unblocked holes. The first question should be independent of the number of holes, unless there is air leaking in.
I would also guess that the degree of flexibility and elasticity would play a role.
Total "grab" is vacuum times area, so the challenge is is maximize the product of vacuum times area when working with flexible materials. Some ideas:
1) High vacuum over small areas. This would be the case of the 8 holes you mention. With high enough vacuum this might work.
2) Low vacuum over a large area. Your second figure with vacuum low enough that the parts do not suck together. Just make the area large enough.
3) Let the parts suck together, but add channels so air can flow to the suction source. Make the suction cup in your second figure with a knurled surface so that contact is only at the points of the knurls. You get the advantage of both large vacuum area and high vacuum.
Likes Ketch22
Thanks for you replies!
@anorlunda Could you explain how your second question is relevant? I don't really understand that. The pump that I use has maximum pressure of 600mmHg. I am not familiar with this unit. Does it mean that this also counts the other way around?
@hrmichler Thanks for the suggestions! The third one seems like a great alternative. Am I correct that I could create the same effect by increasing the number of air holes?
It is just a matter of time. With two holes, you can pump out twice as much air per second as with one hole.
If you have a limited time between first contact and lifting, then that is a constraint.
mmHg is a measurement of pressure (or vacuum, as the case may be), and is the pressure required to change the height of a column of mercury (Hg), in this case, by 600 millimeters. Historically, mercury hasn't been isn't the only fluid, nor metric units the only ones used. Approximate conversions (ignoring temperature, for instance, inches of mercury is specified at 32°F while water column is specified at 60°F; mmHg is at 0°C while mm water is at 4°C).
600 mm Hg = 600 torr (another unit name you may see) = 23.6 inches of mercury = 799.9 millibar =
8157 mm water = 321.4 inch of water (often abbreviated as "in. w.c." - inches of water column) = 11.60 PSI
Thanks for your input guys. I can really work with this!
@Asymptotic, thanks, makes it a lot clearer!
A couple observations. 1) if the cups are made of a silicone material you will need to work on the attachment. At higher levels of vacuum the lifting capacity will exceed the strength of the material if it is a direct bolt in or screw type anchor. 2) In vacuum bag applications used in composite manufacture and repair, a non woven fabric is placed inside the bag next to the film. Even when drawn down to high levels of vacuum the fabric still allows air to travel laterally and be drawn out at the ports. One could go with either design if there was a flow space as jrmichler said.
Related to Maximum suction force in a suction cup
What is maximum suction force in a suction cup?
The maximum suction force in a suction cup is the amount of force that the cup can exert when attached to a surface. It is determined by the strength of the vacuum created between the cup and the surface.
What factors can affect the maximum suction force in a suction cup?
The maximum suction force in a suction cup can be affected by the surface material, the size and shape of the cup, and the smoothness and cleanliness of the surface. Temperature and humidity can also play a role in the strength of the vacuum.
How is the maximum suction force measured?
The maximum suction force in a suction cup is typically measured in pounds or newtons. It is determined by the amount of weight the cup can hold before detaching from the surface.
Can the maximum suction force be increased?
Yes, there are some ways to increase the maximum suction force in a suction cup. Using a larger cup or increasing the surface area can increase the strength of the vacuum. Ensuring that the surface is clean and smooth can also improve suction force.
What are common uses for high maximum suction force in suction cups?
Suction cups with high maximum suction force are often used for hanging or mounting items, such as shelves, hooks, and signs. They are also commonly used in industrial settings for lifting and handling materials.
  • Mechanical Engineering
  • Other Physics Topics
