Maximum Velocity for different accelerations
In summary, the maximum velocity that the jet could achieve is determined by the fighter model in the class being considered and the drag force on the plane.
Noah Drakes
Force of jet= A(r(t))4/3
A: constant determined by the fighter model in the class being considered and the drag force on the plane
r(t): the rate of fuel consumption as a function of time
Consider 3 possible situations for r(t):
1. when the rate is constant for the duration of the acceleration period
2. when the rate is steadily decreasing for the duration of the acceleration period
3. when the rate decreases at a decreasing rate as the plane accelerates
For each of these you should assume that the rate is initially 500 ffu (fighter fuel units)/min,
and for each it is reasonable to suppose an acceleration period of 10 minutes.
Determine-in terms of the characteristics of the fighter (m and A)- the maximum velocity obtained by the jet
F=ma
I set F=ma equal to Fjet = A(r(t)^4/3. So ma=A(r(t)^4/3 .
Now i solved for "a" to get an equation for acceleration: a=(A(r(t)^4/3)/(m)
Then i differentiated the equation to get velocity : A/m * 3/7 (r(t) ^ (7/3)
confused on how to approach the problem from here. I have a test on wednesday with a problem similar to this problem. It would be immensly helpful if someone solved the problem explaining each step and why.
I am new to this community by the way.
It is apparent that you are new. We absolutely do not provide solutions to homework-type questions. We can provide hints and ask probing questions and find mistakes, but doing your work for you is verboten.
Can you say what differences there are between the 3 questions in your problem statement? How do the differences help you to approach the overall problem?
Ok i understand.
The differences between each statement is the state of (r(t)). It is either constant, increasing, or decreasing.
So that implies i would have to manipulate the value of (r(t)). When (r(t)) is constant its value remains at 500. When the rate is decreasing steadily, however, i would subtract a small value from 500 ffu for a few increments. So i would plot the values when (r(t)) = 490, 4980, 470, 460 and so on ? Am I on the right track.
Noah Drakes said:
Ok i understand.
But this doesn't seem right. The jets' fuel consumption would never stay constant during an acceleration period. Am i misinterpreting the meaning of (r(t))?
Differentiating acceleration will give jerk, not velocity. Anyway, it looks like you tried to integrate, but the expression you wrote for the integral would only be correct if r(t)=t.
You need to pick one of the three cases, rewrite the expression for a to match that case, and then integrate.
Why not?
Why not?
Haha whoops.
Why not?
Ok so if r(t) stays constant, and the initial value for r(t) is 500 ffu, then i should integrate the equation (A/m) * 5004/3. but would i integrate with respect to A or m ?
You are obtaining a velocity from an acceleration. What variable connects those?
and why am i integrating, to get the maximum velocity ?
If an object moving at velocity u at time t0 has acceleration a=a(t), what is its velocity at time t1?
If a(t)>0 all that time, when does the maximum velocity occur?
To find the velocity you would take the integral of a (V = ∫ a(t) ) then plug t1 into the equation for V.
the max velocity occurs when a = 0
Yes, except that you have not factored the variables u and t0 that I specified into that.
I specified a>0 throughout the interval.
V = (u) + (a * t) ?
Noah Drakes said:
V = (u) + (a * t) ?
That is only for constant acceleration. Combine the two attempts, and don't forget to specify both bounds on the integral.
i feel stupid. i know this isn't a hard problem. i feel like I am wasting your time
t0 t1(v-t)/u
time
Noah Drakes said:
t0 t1(v-t)/u
The bounds are right, but the rest makes little sense. You cannot subtract a time from a velocity, and dividing by the initial velocity??
Go back to the integral you had in post #11. Fill in the variable of integration and the bounds. That is the generalised form of a*(t1-t0) when a is varying. It remains to use u the same way that you did in post#13.
t0t1 = u + a * (t1 - t0) da
You do not seem to understand the fundamentals of integration. The expression on the right is only for constant acceleration, and anyway does not correspond to the expression on the left because the one on the left does not include u.
If the acceleration is constant from t0 to t1 then the gain in velocity is a(t1-t0). If you draw an acceleration-time graph it will be the area of the rectangle formed by the graph, the t axis and the two vertical lines t=t0 and t=t1, i.e. it will be a(t1-t0).
If the acceleration is not constant then you still want the area bounded by the graph of a and those other three lines, but it is no longer a simple rectangle. The principle of integration is that we slice up the shape into very small time intervals, i.e. thin vertical strips. Each strip can be approximated as a rectangle. Then we add all these rectangles together. In notation, we write this as ##\int_{t_0}^{t_1}a.dt##. As in the constant case, this gives us the increase in velocity from time t0 to t1, so to get the velocity at t1 we need to add the velocity at t0.
With that explanation, can you now write the correct formula for the variable acceleration case?
Ok, I think i Got it
So the equation for velocity when acceleration varies from t0 to t1 is V=∫t0 t1 (A/m) (r(t)) 3/4
where t1 = 10 and t0 is 0
and of the initial value of r(t) is 500
V= ∫t0 t1 (A/m) (r(t))4/3
Yes and no.
That integral gives the increase in velocity in the time interval. If there is an initial velocity you would need to add that on. Strangely, the question does not specify an initial velocity, so unless you have omitted that in the problem statement I suppose you will have to take it as being from a standing start... very strange for a jet already in the air.
You are still leaving out the ".d" term, the one that specifies the variable of integration, as in ∫y.dx. You may think that is implied, but strictly speaking it is not.
Related to Maximum Velocity for different accelerations
What is maximum velocity?
Maximum velocity is the highest speed that an object can reach under specific conditions, such as acceleration and resistance.
How is maximum velocity calculated?
Maximum velocity can be calculated using the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time.
What factors affect maximum velocity?
The factors that affect maximum velocity include the acceleration of the object, the resistance or force acting against it, and the mass of the object.
How does acceleration impact maximum velocity?
Acceleration directly affects maximum velocity, as a higher acceleration will result in a higher maximum velocity. This is because acceleration is the rate of change of velocity.
What is the relationship between maximum velocity and distance?
The relationship between maximum velocity and distance is dependent on the acceleration of the object. A higher acceleration will result in a shorter distance needed to reach maximum velocity, while a lower acceleration will result in a longer distance.
