- #36
anorlunda
Staff Emeritus
- 11,308
- 8,744
Let's do a little back of the envelope calculations.
https://en.wikipedia.org/wiki/Electrolysis_of_water
https://en.wikipedia.org/wiki/Respiratory_minute_volume
So 50 liters of air per minute is 3000 liters per hour, of which 3000*0.21 or 630 liters is oxygen. That is 0.9 kg oxygen/hour, that means you need 50*0.9=45 kw of electric power to supply your own oxygen. And that makes no correction for the pressures needed at scuba depth, nor any correction to capture and recirculate the other 79% of the breathing mixture.
Compare 45,000 watts for a rebreather with 10 watts for cell phone charger, and you see that the energy needs for an electrolysis rebreather are about 4500 times more than what your lungs can produce.
Efficiency of modern hydrogen generators is measured by power consumed per standard volume of hydrogen (MJ/m3), assuming standard temperature and pressure of the H2. The lower the power used by a generator, the higher would be its efficiency; a 100%-efficient electrolyser would consume 39.4 kilowatt-hours per kilogram (141,840 J/g) of hydrogen,[17] 12,749 joules per litre (12.75 MJ/m3). Practical electrolysis (using a rotating electrolyser at 15 bar pressure) may consume 50kWh/kg, and a further 15kWh if the hydrogen is compressed for use in hydrogen cars
Minute ventilation during moderate exercise may be between 40 and 60 litres per minute.
