Maximum voltage in the primary circuit of a transformer
The discussion focuses on calculating the maximum voltage in the primary circuit of a transformer, where the induced voltage is derived from the formula V=-N(dφ/dt). The effective voltage calculated is approximately 3.12 V, leading to a maximum voltage of around 4.4 V. However, the expected result is 4.9 V, prompting a request for clarification on the discrepancy. The resolution involves recognizing that the voltage function V(t) relates to the magnetic field B(t) through sinusoidal functions, leading to the correct calculation of V0 as approximately 4.9 V. This highlights the importance of accurately applying the principles of electromagnetic induction in transformer circuits.
lorenz0
The primary circuit of a transformer has ##N=240## windings, each one with area ##S=10cm^2##. In the primary circuit flows a sinusoidally alternating current. The magnetic field in the iron core of the transformer goes from the maximum value of ##B_0=65mT## along the direction perpendicular to the windings to the exact same value but in the opposite direction in ##\Delta t=10 ms##.
Find the maximum voltage in the primary circuit.
##V=-N\frac{d\phi(\vec{B})}{dt}##, ##V_{max}=\sqrt{2}V_{eff}##
The alternating current will create an induced voltage given by ##V=-N\frac{d\phi(\vec{B})}{dt}=-N\frac{\Delta\phi(\vec{B})}{\Delta t}=N\frac{2 B_0 S}{\Delta t}=\frac{240\cdot 2\cdot 65\cdot 10^{-3}\cdot 10\cdot 10^{-4}}{10\cdot 10^{-3}}=3.12 V## and since this is the effective voltage, the maximum voltage will be ##V_{max}=\sqrt{2}V_{eff}=\sqrt{2}\cdot 3.12 V\approx 4.4 V##. Now, the result given is ##4.9 V## but I haven't been able to figure out where I have made a mistake so I would be grateful if someone could point it out to me, thanks.
lorenz0 said:
Homework Statement: The primary circuit of a transformer has ##N=240## windings, each one with area ##S=10cm^2##. In the primary circuit flows a sinusoidally alternating current. ...
You seem to do ##\Delta \Phi/\Delta t## as if it were a sawtooth ...
Likes lorenz0 and berkeman
Ah, I think I have understood now. Since ##V(t)=V_0\sin(\omega t)## it must be that ##B(t)=B_0\cos(\omega t)## with ##\omega=2\pi f=\frac{2\pi}{T}=\frac{2\pi}{2\delta t}=100\pi\ \frac{rad}{s}## so that ##V(t)=V_0\sin(\omega t)=-N\frac{d\phi(\vec{B})}{dt}=-N\frac{d}{dt}\left( B_0\cos(\omega t)S )\right)=NB_0S\omega\sin(\omega t)## thus ##V_0=NB_0S\omega=240\cdot 65\cdot 10^{-3}\cdot 10^{-3}\cdot 100\pi\ V\approx 4.9\ V.##
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
