Maximum volume from a rectangular cardboard
In summary, the conversation discusses finding the maximum or minimum value of a function using the first derivative and applying it to a specific problem involving a box's volume. The solution involves finding the critical point at which the derivative is equal to zero, which in this case is approximately 1 and 2/3.
Karol
1,380
First derivative=maxima/minima/vertical tangent/rising/falling
When f'(x)>0 → the function rises
$$V=(15-2a)(8-2a)=4a^2-46a+120$$
$$V'=8a-46,~~V'=0\rightarrow a=5.75$$
But: ##~2a<8,~~V(a=4)=0##
So 5.75>4
And: ##~V''=8## so it holds water, it should be inverse.
Karol said:
V=(15−2a)(8−2a) = 4a2−46a+120V = (15−2a)(8−2a)=4a2−46a+120​
V=(15−2a)(8−2a) ? or Volume = length x breadth ? That can't be right can it ?
How many dimensions do you need to multiply together to get the volume of a box ?
$$V=(15-2a)(8-2a)a=4a^3-46a^2+120a$$
$$V'=12a^2-92a+120,~V'=0\rightarrow a=1\frac{2}{3}$$
Thank you Nidum
Likes Nidum
Related to Maximum volume from a rectangular cardboard
1. What is the formula for calculating the maximum volume of a rectangular cardboard?
The formula for calculating the maximum volume of a rectangular cardboard is V = lwh, where V is the volume, l is the length, w is the width, and h is the height.
2. How do I determine the dimensions of the cardboard to achieve maximum volume?
To determine the dimensions of the cardboard, you can use the formula V = lwh and plug in different values for the length, width, and height until you find the combination that results in the highest volume. Alternatively, you can use calculus to find the critical points and determine the dimensions that result in the maximum volume.
3. Is there a specific shape that will give me the maximum volume for a given amount of cardboard?
Yes, a cube is the shape that gives the maximum volume for a given amount of cardboard. This is because all sides of a cube are equal in length, resulting in a balanced distribution of volume.
4. Can I use this formula for any type of cardboard, such as corrugated or thick cardboard?
Yes, the formula V = lwh can be used for any type of rectangular cardboard, regardless of thickness or material. However, keep in mind that the dimensions of the cardboard will affect the maximum volume.
5. Are there any real-world applications for calculating the maximum volume of a rectangular cardboard?
Yes, determining the maximum volume of a rectangular cardboard is useful in optimizing packaging and storage solutions. It can also be applied in construction and engineering to determine the most efficient use of materials.
10K
