Maximze power delivered to load (lossless tranmsion line)
  • Thread starter Thread starter nagr
    Line Load Power
Maximizing power delivery to a load occurs when the characteristic impedance (Z0) equals the load impedance (ZL), resulting in zero reflection. The discussion highlights confusion regarding the derivation of the average power equation and the calculation of input impedance (Zin) for a transmission line. The participant calculated Zin as 12.5+j12.5 but struggled with the subsequent steps to maximize power delivery. They attempted to find the reactive component (X) that would cancel the imaginary part of Zin, ultimately leading to a resistance (Rg) of 25. Clarification on the mathematical approach and equations used for calculating power and impedance was requested for further understanding.
nagr
Time Avg. Power = \frac{|V0+|^2}{2*Z0} [1-|\Gamma|^2]
for line of l=\frac{λ}{4}+n\frac{λ}{2} (where n=0 here), Zin=\frac{Z0^2}{ZL}
Bit confused what to do in the 1st part? I know that max. power is delivered to load when Z0=ZL because then there will be no reflection, so |\Gamma|=0 which is obvious from the equation that power is maximized (also my professor explained this). But to prove this, am i expected to take the derivative of the equation for time avg. power, with respect to Z0=Zin=R+jX? I am unsure how to do this, first of all. Also here in this problem (c) Z0 is not same as ZL so power delivered is not maximized. But using the equation above I calculated Zin=12.5+j12.5 from which I found X=12.5 and Rg i assumed was the real part of Zin=12.5. i was wondering though if I did this right so far.
1. Compute Zin which will be a function of Z0 and θ of the line, and ZL. θ = βx, β = ω(LC)(1/2), and x = physical length of line. See illustration (b).
2. Compute V across Zin. You can assume Vin = 1.
3. Compute I.
4. Compute power P = |V||I|cos(ψ) or Re{VI*}.
5. Find Rin and Xin which maximize P.
V and I are phasors.
the general equation for Zin in my book is Zin=Z0(\frac{zL+j(tan(βl)))}{1+j(zL*tan(βl))}) where zL=\frac{ZL}{Z0} but i don't think this helps me much. for problem (b), this is what I did so far: since length of line is a special case l=\frac{λ}{4}, i used the equation for Zin I listed and got Zin=12.5+j12.5. so according to figure (b), I thught this would mean Zin in parallel with the shunt element jX, I found the value for X so that the imaginary part would cancel out, so X=-25. this would mean Rg=(Zin||-j25) for maximum power delivery so Rg=25.
ok, my professor explained this to me so obviously i was doing this wrong. If I use the equation he gave me, Pavg=\frac{1}{2}Re(V x I*)=\frac{1}{2} Re[\frac{Vg}{Zg+(Rin+Xin)}((Rin+Xin)(\frac{Vg}{Zg+(Rin-Xin}))] where i substituted Zin=Rin+Xin and use Vg=Vo and I ended up with 1/2 Re[\frac{Vo^2Rin+jVo^2Xin}{(Rg+Rin)^2+X^2}] but I am not very good with math :P so i don't know if i did this right. would appreciate if you could help me out.
  • · Replies 18 ·
