Maxwell distribution of relative velocities
In summary: I have no idea what they are. Hi Violina:You are right, the 4π is there because the equation in the quote gives the distribution for the length of the vector vi. The vi2 comes from the integration over all angles. When doing the integration, you need to keep track of the angle between the two vectors. Regards,Buzz
Violina
I want to calculate the distribution function for the relative velocity v_r = v_1 - v_2 of two particles. Each particle velocity follows the Maxwell distribution for velocities. They have the same mass and temperature.
Can I just multiplicate the Maxwell distributions of the two particles (and normalize it)? Can someone help me?
Thank you!
Hi Violina:
If I understand what you are trying to do, you want the distribution of the relative speed between two particles randomly chosen from those in a gas in equilibrium at a given temperature. You asked:
Violina said:
Can I just multipliate the Maxwell distributions of the two particles ... ?
I think the problem is more complicated than that. Each particle has a velocity vector with a magnitude (speed) defined by the distribution function for the particular temperature, and an random direction orientation equally distributed over all possible angles, that is, the angular distribution between a reference point on a unit spherical surface, and a random point on that surface. Then you use the law of cosines:
to get the length of the difference vector. Then you have to integrate over four variables: 1 and 2 are the product of two Maxwell distributions for the two particles, and 3 and 4 are the longitude and latitude over a spherical surface to get the angle distribution between the two vectors.
Good luck.
Regards,
Buzz
Thank you Buzz.
I think I don't need the cosine term because v_1 and v_2 are vectors and v_r = v_1-v_2 is also a vector. But I think I can't just set in v_r in the Maxwell distribution for velocities?
And I don't know which mass I should set in. Maybe something like: m*|(v_1-v_2)| to get something like a relative mass?
Hi Violina:
For some reason today I am having trouble using the quote tool, so I will quote what I want to discuss using copy and paste.
I think I don't need the cosine term because v_1 and v_2 are vectors​
I think we are on different channels. You need to calculate the joint distribution of two 3D random vectors. In spherical coordinates. Each of the two distributions is a Maxwell distribution of a radial length times a uniform distribution over a unit sphere.
And I don't know which mass I should set in.​
The problem you described in post #1 was about velocities, not momenta. I am not sure how you want to define a momentum problem. If you want the momentum of one particle relative to the position of a second particle, you use the mass of the first particle.
Regards,
Buzz
Thank you very much.
Here is the original exercise. Maybe then you can better understand, what's my problem:
Consider a gas in which the velocities of the particles are isotropically distributed and follow the
f(vi) = 4(pi) *(m/(2 pi k T))^3/2 (v_i)^2 * exp (- mv_i^2/(2kT))
For two random particles i = 1 and i = 2, the (vectors of the) velocity of the centre of mass and the
relative velocity are defined as
V =(v_1 + v_2) /2
v_r = v_1 - v_2
Calculate the distribution F(vr) of the relative velocity in analogy to the Maxwell distribution. Compare
F(vr) and f(v). HINT: Express v1 and v2 in terms of V and vr.
Hi Violina:
I am having some difficulty reading the equation in the quote and matching it with the equation below from Wikipedia.
Here the vector vi is represented in Cartesian coordinates. Note that you have two elements in your equation that are absent from the equation just above.
(1) 4π to the left of the first "*"
(2) vi2 to the left of the second "*"
(1) I am guessing that your 4π is because your equation gives the distribution just for the length of the vector vi while ignoring the various angles of the vector. Remember that 4π is the surface area of a unit sphere, would result from ingratiating the angle distribution over all possible angles.
(2) I have no idea where your vi2 comes from.
The suggestion
is good. The result you want is the distribution of vr. V can be ignored because it is irrelevant to the distribution of vr.
Regards,
Buzz
You should have looked higher up on that page, as Violina's equation is the first one given.
(1) and (2) are because the equation we are considering the Maxwell-Boltzmann distribution of speed. The 4π is indeed due to the angular distribution, while the v2 is due to the density of states: the higher the speed, the more possibilities you have to decompose that speed into different components.
Likes Buzz Bloom
Hi DrClaud:
I appreciate your pointing out to me where Violina's equation came from. I apologize for my carelessness in not noticing this on the Wikipedia page.
I also thank your for explanation about vi2, although I am still somewhat confused. I get that the form with vi2 is part of the difference, along with the 4π, between a distribution of speeds and a distribution of velocities. I am guessing that an additional integration of the vector form in spherical coordinates, with one of the two particles at the origin, would result in the vi2, but I don't understand what that integral would look like from your "the higher the speed, the more possibilities you have to decompose that speed into different components". Can you give a bit more detail about this explanation?
Regards,
Buzz
My answer was maybe too complicated for nothing. It appears the same way when going from Cartesian to spherical coordinates:
\mathrm{d}^3\mathbf{r} \Rightarrow r^2 \sin \theta \, \mathrm{d}r \, \mathrm{d}\theta \, \mathrm{d}\phi
Likes Buzz Bloom
Hi DrClaude:
I think I get it now. The r2 becomes is the vi2 because r is the speed of the velocity vector.
Thank you very much for your response to my question.
Regards,
Buzz
Hi Violina:
I want to suggest again you that use the cosine law, and calculate the distribution of the angle. It comes from choosing a particular orientation angle for v1, like the North pole and allowing the other orientation angle to be any point on a unit sphere. Integrate over the longitude angle, φ, in polar coordinates (see the RHS of post #9 with r2 dr=1) to get the distribution of the angle between v1, the North pole, and v2, which is α = π/2 - θ. Thus
cos α.= sin θ.​
ADDED
I have had an insight following the digestion of DrClaud's posts, together with something I read in the Wikipedia article:
It can also be seen that the Maxwell–Boltzmann velocity distribution for the vector velocity
[vx, vy, vz] is the product of the distributions for each of the three directions:​
Also, each of the three coordinate distributions, f(x), f(y) and f(z) are all the same Gaussian distribution. This means that my suggestion to use the Cosine Law and polar coordinates is a bad idea. Think about combining the factored form of the distribution for three coordinates, x, y, z, for two vectors. Think about the combined distribution for each coordinate separately.
Hope this helps.
Regards,
Buzz
Related to Maxwell distribution of relative velocities
What is the Maxwell distribution of relative velocities?
The Maxwell distribution of relative velocities is a probability distribution that describes the distribution of speeds of particles in a gas or liquid at a given temperature. It is named after physicist James Clerk Maxwell who first described it in the 19th century.
What factors affect the shape of the Maxwell distribution?
The shape of the Maxwell distribution is affected by the temperature and mass of the particles in the gas or liquid. Higher temperatures and lower particle masses result in a wider and flatter distribution, while lower temperatures and higher particle masses result in a narrower and taller distribution.
What is the most probable speed in a Maxwell distribution?
The most probable speed in a Maxwell distribution is the speed at which the largest number of particles are moving. This speed is given by the peak of the distribution curve and is dependent on the temperature and mass of the particles.
How is the Maxwell distribution used in real-world applications?
The Maxwell distribution is used in various fields such as physics, chemistry, and engineering to model the behavior of particles in a gas or liquid. It is also used in the design and testing of technologies such as gas turbines and rocket engines.
Can the Maxwell distribution be applied to all types of particles?
No, the Maxwell distribution is specifically applicable to particles in a gas or liquid. It cannot be applied to particles in a solid or plasma state as their movement is governed by different physical laws.
