Maxwell Equations, Lorentz Force and Coulumb Force
The discussion centers on the relationship between Maxwell's equations, the Lorentz force, and Coulomb's law in describing electromagnetic phenomena. There is uncertainty regarding whether the Lorentz force can be derived from Maxwell's equations, leading to confusion due to conflicting information found online. Maxwell's equations effectively illustrate the connections between electric and magnetic fields, yet their intuitive application alongside the Lorentz and Coulomb forces is questioned. It is noted that the Lorentz force can indeed be derived from Maxwell's equations when considering energy-momentum conservation. Overall, a comprehensive understanding of electromagnetic interactions requires integrating all three sets of equations.
latot
Here the 3 set of equations we know, the Maxwell Equations, Lorentz Force, and Coulumb Force, actually I doubt a lot what set of equations represent all the electromagnetic aspects, I try research over the internet and I found a lot of contradictions in the answers, someone says we can get the Lorentz Force from Maxwell and others not...
In the end, I don't know the right answer, so, what set of equations can represent all the proporties of magnetic and electric things (yes, things, electro-magnetic, electros, protons, waves, etc, etc)?
What I can see in Maxwell equations, they are a nice way to set the relations betwen the magnetic and electric field, but isn't too intuitive if there in the middle of it, the Lorent and Coulmb forces are already applied.
Thx.
Maxwell's equations describe the relationship between charges and the electric and magnetic fields:
Charges define the electric and magnetic fields.
The Lorentz force (of which Coulomb's law is a special case) describes how charges move in the presence of electric and magnetic fields:
Electric and magnetic fields tell charges how to move.
Logically, you need both.
It's an interesting question, perhaps, of how little you need to assume about the Lorentz force in order to derive the precise format from Maxwell's equations. For example:
https://arxiv.org/abs/physics/0206022
Likes vanhees71 and Vanadium 50
You can, however, derive the Lorentz force ##\vec{F}=q(\vec{E}+\vec{v}/c \times \vec{B})## (for a point particle) from the Maxwell equations and energy-momentum conservation. You only need the energy-momentum tensor of the electromagnetic field.
Likes atyy and PeroK
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
