A Maxwell theory invariant under dual field strength tensor application
Mark99
TL;DR Summary
Dual field strength tensor and EOM
Hello everybody! I know in classical field theory adding in the Lagrangian density a term of the form Fαβ (*F)αβ (where by * we denote the dual of the field strength tensor) does not change the EOM, since this corresponds to adding a total derivative term to the action. However when computing the EOMs explicitly through ∂μ(∂L/∂∂μAυ)-∂L/∂Aυ=0, I do not find this to be true.
In particular I get ∂(Fαβ (*F)αβ)/∂∂μAν=4(*Fμν), when the result should be zero. I suppose I am not managing the Levi Civita tensor properly, but I do not understand my mistake. Is there someone who can do this derivation explicitly and show it is zero?
Thank you in advance.
You have the additional term
$$L=F_{\alpha \beta} (^*F)^{\alpha \beta} = F_{\alpha \beta} F_{\gamma \delta} \epsilon^{\alpha \beta \gamma \delta}.$$
The variation is
$$\delta L = 2 \delta F_{\alpha \beta} F_{\gamma \delta} \epsilon^{\alpha \beta \gamma \delta} = 8 \partial_{\alpha} \delta A_{\beta} \partial_{\gamma} A_{\delta} \epsilon^{\alpha \beta \gamma \delta}.$$
Thus, integrating by parts
$$\delta S=\int \mathrm{d}^4 x \delta L = -8 \int \mathrm{d}^4 x \delta A_{\beta} \partial_{\alpha} \partial_{\gamma} A_{\delta} \epsilon^{\alpha \beta \gamma \delta} \equiv 0.$$
Thus ##\delta S=0## is identically fulfilled, and that's equivalent for the Euler-Lagrange equations being fullfilled for all ##A_{\mu}##.
Likes Dale and topsquark
The variation is
Thank you for your answer! I understand that. Is it possibile to get the same result showing that the term ∂(Fαβ (*F)αβ)/∂∂μAν in the equations of motion Is zero? Because I understand why your way Is correct but I do not understand why mine Is not
You can write it as
$$L=4 (\partial_{\alpha} A_{\beta})(\partial_{\gamma} A_{\delta}) \epsilon^{\alpha \beta \gamma \delta}.$$
Then
$$\frac{\partial L}{\partial (\partial_{\mu} A_{\nu})} =8 \delta_{\mu \alpha} \delta_{\nu \beta} (\partial_{\gamma} A_{\delta}) \epsilon^{\alpha \beta \gamma \delta}= 8 (\partial_{\gamma} A_{\delta}) \epsilon^{\mu \nu \gamma \delta}.$$
Then contracting with ##\partial_{\mu}## gives
$$\partial_{\mu} \frac{\partial L}{\partial (\partial_{\mu} A_{\nu})} = 8 \partial_{\mu} \partial_{\gamma} A_{\delta} \epsilon^{\mu \nu \gamma \delta}=0.$$
Since ##\partial L/\partial A^{\mu}=0##, that shows that the Euler-Lagrange equations are identically fulfilled, i.e., this term in the Lagrangian doesn't contribute to the equations of motion.
Likes LittleSchwinger, topsquark and dextercioby
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
