Maxwell's Capacitor argument for a time independent Current
The discussion revolves around the concept of "time independent current," which is clarified to mean a constant current that does not vary with time, contrasting with time-dependent currents like AC. Participants seek to understand this terminology and its implications in the context of capacitors. The conversation highlights confusion over the term "time independent," suggesting that "constant current" may be a more accurate description. The distinction between constant and time-dependent currents is emphasized, particularly in relation to how they interact with capacitors. Overall, the thread seeks clarity on the definitions and examples of these types of currents.
Shreya
Why can't we apply the. Maxwells argument to a time independent Current applied to a capacitor, to conclude the existence of a displacement Current inside a capacitor?
Maxwells argument considered a pot like surface between the plates of a capacitor with its open end outside. And argued that since the current enclosed is 0, B must be 0 just inside the capacitor, which is not true.
Ampere Maxwell Law
Is it because the current applied to a capacitor will never be time independent? Please help me out🙏
Sorry, what is a "time independent current"? Can you define that, or give some examples?
What I meant was a constant current - one which is not a function of t. A time dependent current would be AC Current. I am not sure if the name time independent is correct.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
