Maxwell's equations and plane waves
So I don’t understand why you’re using that expression.You’re using the real part of the complex conjugate of that expression. Why? If you’re not working with time averages, why not just use the real part of the expression itself? You’re using the time average of the real part of the complex conjugate of the expression. That doesn’t make sense to me. I think you want to use the time average of the real part of the expression itself, which is related to the Poynting vector. But I may be misunderstanding you.I think you need to use the plane wave solutions for the fields. You have expressions for the fields in terms of their magnitudes and directions
stripes
266
Show that the general relationship from Maxwell's equations for the conservation of energy
[itex]
\nabla \cdot \textbf{S} + \frac{\partial u}{\partial t} = 0,
[/itex]
where
[itex]
u = \frac{1}{2} \epsilon _{0} \left| \textbf{E} \right| ^{2} + \frac{1}{2 \mu _{0}} \left| \textbf{B} \right| ^{2},
[/itex]
holds for plane wave solutions to Maxwell's equations.
Plane wave solutions:
[itex]
\textbf{E} = E_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)}
[/itex]
[itex]
\textbf{B} = B_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)}
[/itex]
I need a starting point. I can use vector identities to try and derive the answer but I need to know what to start from. I've tried starting from various equations but I can't seem to end up with the conservation law. Any help is appreciated.
Can you show a little of what you tried? Note that your equations below are inconsistent:
stripes said:
[itex]
[/itex]
[itex]
[/itex]
On the left side of the equations you have vector quantities, but on the right side you have scalar quantities.
Yes those should be vectors on the right hand sides of those expressions.
Here is what I'm doing:
[itex]\textbf{S} = \frac{1}{\mu _{0}}( \textbf{E} \times \textbf{B})[/itex]
[itex]\nabla \cdot \textbf{S} = \frac{1}{\mu _{0}} \nabla \cdot ( \textbf{E} \times \textbf{B})[/itex]
[itex]=\frac{1}{\mu _{0}}( \textbf{B} \cdot (\nabla \times \textbf{E}) - \textbf{E} \cdot (\nabla \times \textbf{B})[/itex]
[itex] = \frac{1}{\mu _{0}} (\frac{- \partial}{\partial t}(\textbf{B} \cdot \textbf{B}) - \frac{\partial}{\partial t}(\frac{1}{v^{2}} ( \textbf{E} \cdot \textbf{E})[/itex]
[itex] = \frac{- \partial}{\partial t} \frac{1}{\mu _{0}} (B + \frac{1}{v^{2}} E)[/itex]
But I don't know how to get the vector lengths squared...nor do I know how to implement epsilon and mu...and how do I show this specifically for plane waves??
You have left out the complex conjugation. Note that [tex]\textbf{S} = \frac{1}{\mu _{0}}( \textbf{E} \times \textbf{B}^*)[/tex] and so on. Then when you form B dot B you get the amplitude squared.
In fact, it's usually defined in terms of H instead of B. Many authors also include a factor of 1/2 to give power units with the peak amplitudes E0 and B0. Then it's [tex]\textbf{S} = \frac{1}{2}( \textbf{E} \times \textbf{H}^*)[/tex]
##\textbf{B} \cdot (\nabla \times \textbf{E}) = \textbf{B} \cdot( \frac{- \partial}{\partial t}\textbf{B})=-\frac{1}{2}\frac{ \partial}{\partial t}(\textbf{B} \cdot \textbf{B}) = -\frac{1}{2}\frac{ \partial}{\partial t}B^2##, etc.
Your approach here is going to get the result in a general way rather than specifically for plane waves. If you want to show the result for plane waves, then use the plane wave expressions for ##\textbf{E}## and ##\textbf{B}## at the beginning. You can avoid issues with complex numbers by using just the real parts of your expressions for ##\textbf{E}## and ##\textbf{B}##.
You will need to keep in mind the relative orientations of ##\textbf{E}##, ##\textbf{B}##, and ##\textbf{k}## for plane waves. You can simplify things by orienting your coordinate axes in an appropriate way. You will also need to know the relationship between the magnitudes of ##\textbf{E}## and ##\textbf{B}## for plane waves.
Well as much as I'd love to use the real parts, I don't think I'd get full marks. I think we're expected to show this for all complex numbers. But it'd be so much easier using the real parts.
[itex]= \frac{1}{\mu _{0}}\nabla \cdot((\textbf{ E }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)}) \times(\textbf{ B }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)}))[/itex]
[itex] = \frac{1}{\mu _{0}}( \textbf{ B }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)} \cdot (\nabla \times \textbf{ E }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)}) - \textbf{ E }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)} \cdot (\nabla \times \textbf{ B }_{0} e^{i(\textbf{k} \cdot \textbf{r} - \omega t)})[/itex]
Now can I substitute in some [itex]\frac{\partial}{\partial t}[/itex]'s as I did before? I just don't know how I'm going to get rid of those exponentials...
Why are you ignoring what marcusl said above?
I didn't. He marcusl suggested I use the real parts. I addressed that. Then marcusl said to use the plane wave solutions from the beginning, which I am.
Obviously this stuff is very confusing. I think what I'm trying to say is that I really don't get this stuff...
TSny said that. Marcusl pointed out you left out the complex conjugation, which would take care of the complex exponentials.
Before I carry on, where does the factor of 1/2 come from when factor the partial differential operator?
derivative of a square...
ehild
Oh right. Okay I am plugging away at things.
I’m not seeing the relevance of the expression ##\frac{1}{\mu _{0}}( \textbf{E} \times \textbf{B}^*)## for this problem.
If the fields vary with time sinusoidally, then this expression is related to the time average of the Poynting vector through the relation
##\langle\textbf{S}\rangle## = Real part of ##\frac{1}{2\mu _{0}}( \textbf{E} \times \textbf{B}^*)##
For example, see here .
But I don’t think you’re working with time averages in this question.
Using the time average gives the correct answer for harmonically varying fields. The expression u is the instantaneous field energy and the average field energy--they are the same for harmonic traveling waves. Similarly, the time-averaged power flux density equals the instantaneous power flux density in this case.
The contribution to the instantaneous u from the plane wave's electric field E(r,t) = E0cos(k[itex]\cdot[/itex]r-ωt) is
uE =## \frac{\epsilon_0}{2}##E02cos2(k[itex]\cdot[/itex]r-ωt)
This fluctuates in time. Likewise, for the magnetic field contribution. (The time averages of course are independent of time.)
For the instantaneous u, ##\frac{\partial{u}}{\partial{t}} \not= 0## at general times t.
My interpretation of the problem is that you want to show ##\nabla\cdot\textbf{S}+\frac{\partial{u}}{\partial{t}} = 0## for the instantaneous quantities.
The energy conservation law [tex]\nabla\cdot\textbf{S}+\frac{\partial{u}}{\partial{t}}=-\textbf{E}\cdot\textbf{J}[/tex] is actually derived for a volume; the change in energy within the volume plus the energy removed by a sink must equal the integrated power entering (exiting) the closed surface. As Reitz and Milford point out,
"It is tempting to interpret E×H itself as the energy flow per unit time per unit area. The latter interpretation leads to certain inconsistencies; the only interpretation which survives scrutiny is that the integral of E×H over a closed surface represents the rate at which EM energy cross the closed surface."
Since we are talking about a volume, then we can take the spatially integrated instantaneous energy equal to the time-averaged energy. The time averaged quantity is therefore valid for this problem. In fact, Jackson uses time averaged quantities when writing Poynting's Theorem for harmonic fields (section 6.10, 2nd ed.).
I'm not sure why you guys are talking about time-averaging and spatial integration. The equation:
Comes directly from maxwell's 4 laws (in differential form). The only possible tricky part might be using complex numbers instead of the reals.
Edit: now I read through the posts on the previous page more carefully, I don't understand the use of complex conjugates... The way I would do this question is to use the E and B given, plug into the above equation (with J=0) and show it is consistent.
Edit again: You can also show that (assuming J=0), the above equation (with J=0) is true. (even better than just 'consistent'). But you would have to use more than just the given form of the E and B fields. (i.e. you need to use Maxwell's equations, or the relation between the E and B fields for plane waves)
final edit: for clarity, when I say plug in E and B, I mean using the usual definition of the Poynting vector
[tex]\textbf{S} = \frac{1}{\mu_0} \textbf{E} \times \textbf{B} [/tex]
I've deleted one of the posts as I felt it might be effectively providing a complete solution. Please keep in mind the idea is to guide students so they can work the problem out on their own, not to show how easy it is to solve it. If the helpers want to discuss the problem further, I suggest you do so via private messages.
I remember one piece of good advice in the post. The method the OP should use will depend on whether the OP wants to show the relation for time-averaged quantities, or for the instantaneous quantities.
FAQ: Maxwell's equations and plane waves
1. What are Maxwell's equations?
Maxwell's equations are a set of four fundamental equations in classical electromagnetism that describe the behavior of electric and magnetic fields. They were first published by James Clerk Maxwell in 1865 and are widely considered to be one of the most important discoveries in physics.
2. What are the four main equations in Maxwell's equations?
The four main equations in Maxwell's equations are: Gauss's Law, which relates the electric field to the distribution of electric charges; Gauss's Law for magnetism, which relates the magnetic field to the distribution of magnetic charges; Faraday's Law, which describes how a changing magnetic field induces an electric field; and Ampere's Law, which relates the magnetic field to the electric current and displacement current.
3. What are plane waves in the context of Maxwell's equations?
Plane waves are a type of electromagnetic wave that are characterized by their flat, uniform wavefronts and constant frequency. They are solutions to Maxwell's equations and can be described by a sinusoidal function of time and space.
4. How are plane waves related to the speed of light?
In vacuum, the speed of light is equal to the speed of a plane wave. This is because light is an electromagnetic wave and follows the same rules and equations as other types of electromagnetic waves. This relationship is described by the equation c = 1/√(μ0ε0), where c is the speed of light, μ0 is the permeability of free space, and ε0 is the permittivity of free space.
5. What are some applications of Maxwell's equations and plane waves?
Maxwell's equations and plane waves have many important applications in modern technology, including telecommunications, radar and satellite communication, radio and television broadcasting, and medical imaging. They are also used in the study of light and optics, as well as in the development of new materials and devices for electronics and photonics.
