May i know how to integrate [1 / (4 + x^2)^1/2] using trig?
In summary, trigonometric substitutions involve using either \cos^2x + \sin^2x = 1 or \sec^2x = 1 + \tan^2x identities to make a substitution and simplify the integral. The choice of which identity to use depends on the form of the radical expression in the integral.
teng125
416
may i know how to integrate [1 / (4 + x^2)^1/2] using trigo substitution??
pls help...
Well, you have a few trig identities, see which one is useful.
Here, you could use the fact that [itex]\sec ^2 x = 1 + \tan ^2 x[/itex].
So try the substitution [itex]x = 2\tan y \Leftrightarrow dx = \frac{2}{{\cos ^2 y}}dy[/itex]
oh,i got it...can u pls tell me how do you know which frigo identities to choose when u you see the question in general??(not the question above)
pls...
For trigonometric substitutions, there are two fundamental identities which are often used:
[tex]\begin{array}{l}
\cos ^2 x + \sin ^2 x = 1 \Leftrightarrow \cos ^2 x = 1 - \sin ^2 x \\
\sec ^2 x = 1 + \tan ^2 x \Leftrightarrow \tan ^2 x = \sec ^2 x - 1 \\
\end{array}[/tex]
The first one can be used for radical expressions of the form [itex]\sqrt {a^2 - x^2 } [/itex] where you then choose the substitution [itex]x = a\sin y[/itex].
The second one can be used for two types: yours, which was of the form [itex]\sqrt {x^2 + a^2 } [/itex] (you then do [itex]x = a\tan y[/itex]) or those of the form [itex]\sqrt {x^2 - a^2 }[/itex] (then it's [itex]x = a\sec y[/itex]).
FAQ: May i know how to integrate [1 / (4 + x^2)^1/2] using trig?
What is the formula for integrating 1 / (4 + x^2)^1/2 using trig?
The formula for integrating 1 / (4 + x^2)^1/2 using trig is ∫ 1 / (4 + x^2)^1/2 dx = 1/2 arcsec(x/2) + C.
What is the significance of using trigonometric functions in this integration?
Using trigonometric functions in this integration allows us to rewrite the integrand in terms of inverse trigonometric functions, making the integration process easier and more efficient.
Can this integration be solved without using trigonometric functions?
Yes, it is possible to solve this integration without using trigonometric functions. However, the process may be more complex and may require the use of other mathematical techniques such as substitution or partial fractions.
Are there any special considerations or restrictions when using trigonometric functions in this integration?
Yes, when using trigonometric functions in this integration, it is important to consider the domain of the inverse trigonometric functions, as well as any potential singularities in the integrand.
How can I check if my integration using trigonometric functions is correct?
You can check the correctness of your integration by taking the derivative of the resulting integral and comparing it with the original integrand. Additionally, you can use online integration tools or ask a colleague to verify your solution.
