Maybe triangle inequalities theorem
In summary, to prove that if a2+b2=1, and c2+d2=1, then ac+bd ≤1, we can use the triangle inequality to show that (a+c)2+(b+d)2 ≤ (a2+c2)+(b2+d2) = 2, and since (a+c)2+(b+d)2 ≥ 0, we have ac+bd ≤ 1.
azizlwl
1,066
Prove: If a2+b2=1, and c2+d2=1, then ac+bd ≤1
Maybe triangle inequalities theorem.
For this question to make sense, I think a,b,c and d must be Real numbers. Is this given?
Hint: What is (a+c)2+(b+d)2?
Thanks
At the beginning of the chapter, "An inequalities is a statement that one(Real)number is greater than or less than another".
Is there inequalites in complex number?
(a+c)2+(b+d)2≥0
equal zero if both factors=0, greater than zero if one or both factor not equal to zero.
a2+c2+2ac +b2+d2+2bd≥0
2+2ac+2bd≥0
ac+bd≤-1 ?
So it should be
(a-c)2+(b-d)2≥0
Equal to zero if a=c and b=d, greater than zero if one or both of components of the factors not equal.
a2+c2-2ac +b2+d2-2bd≥0
2-2ac-2bd≥0
ac+bd≤1
azizlwl said:
Thanks
One can extend the definition of an inequality to deal with complex numbers (by comparing their real and imaginary parts), but this isn't nessecary in this case since if [itex]a[/itex] and [itex]c[/itex] are both purely imaginary, their product will still be real (but the inequality that you are supposed to prove may not be satisfied).
Anyways, if you are studying real numbers then it is probably safe to assume all 4 numbers (a,b,c & d) are real.
2+2ac+2bd≥0
ac+bd≤-1 ?
This is true, but not all that useful here. instead of looking at the lower limit of (a+c)2+(b+d)2, use the triangle inequality (twice) to look at its upper limit.
Keep in mind, that if x2+y2=1 (for real-valued x & y), then |x|^2=x^2=1-y^2≤1 :wink:
So it should be
(a-c)2+(b-d)2≥0
2-2ac-2bd≥0
ac+bd≤1
This method also works and is even simpler than mine!:approve:
But (not relevant to this question but just so that other readers do not get the wrong idea) that extension of inequality does not make the complex numbers an ordered field. In particular, if x< y and 0< z, it is NOT necessarily true that xz< yz.
Related to Maybe triangle inequalities theorem
1. What is the Maybe Triangle Inequalities Theorem?
The Maybe Triangle Inequalities Theorem is a mathematical concept that states that for any triangle, the sum of any two sides must be greater than the length of the third side. This theorem is not always true, hence the "maybe" in the name.
2. How is the Maybe Triangle Inequalities Theorem different from the Triangle Inequality Theorem?
The Triangle Inequality Theorem states that for any triangle, the sum of any two sides must be greater than the length of the third side. This theorem is always true. The Maybe Triangle Inequalities Theorem, on the other hand, is not always true and allows for the possibility that the sum of two sides may be equal to or less than the length of the third side.
3. When can the Maybe Triangle Inequalities Theorem be applied?
The Maybe Triangle Inequalities Theorem can be applied when dealing with triangles that do not follow the traditional triangle inequality rule. This could include non-Euclidean triangles or triangles on curved surfaces.
4. Can the Maybe Triangle Inequalities Theorem be used to prove other theorems?
Yes, the Maybe Triangle Inequalities Theorem can be used as a starting point to prove other theorems related to triangles. It can also be used in combination with other theorems to prove more complex concepts.
5. What is the practical application of the Maybe Triangle Inequalities Theorem?
The Maybe Triangle Inequalities Theorem has practical applications in fields such as geometry, physics, and engineering. It can help in solving problems involving non-traditional or non-Euclidean triangles, as well as in creating new mathematical models and concepts.
