Python MCMC algorithm -- understanding some paremeters
  • Thread starter Thread starter Arman777
    Algorithm
The discussion revolves around understanding parameters in the MCMC program SimpleMC, specifically focusing on the Metropolis-Hastings algorithm. Key parameters include nsamp (number of samples), skip (burn-in period), GRstop (Gelman-Rubin convergence criterion), and checkGR (steps to check GR-criteria). The temperature parameter (temp) is crucial for sampling, while chainno indicates the number of CPUs used, with a setting of 1 for single CPU operation. The user has experimented with different values for temp and chainno, finding that setting chains to 4 and temp to 0.2 yields successful results. Understanding these parameters is essential for effective analysis in MCMC applications.
Arman777
Insights Author
Recently I have shared a question about a program called SimpleMC and how to run it.
Running a Github File on VS code for windows 10- File system problem ( | Physics Forums
I am trying to understand an MCMC program. I manage to run it, but I am trying to understand the meaning of the some parameters in the analysis.
The code is something like this
Python:
[mcmc]
;Nsamples
nsamp   = 50000
;Burn-in
skip    = 300
;temperature at which to sample
temp    = 2
; Gelman-Rubin for convergence
GRstop  = 0.01
;every number of steps check the GR-criteria
checkGR = 500
;1 if single cpu , otherwise is giving by the nproc-> mpi -np #
chainno = 0
This is for the metropolis-hastings algorithm. How my results depend on these parameters or what these parameters mean ?
I understood the nsamp and skip, I also kind of know what GRstop and checkGR means but I have no idea what temp and chainno means.
Technology news on Phys.org
Perhaps you can find the meaning behind the parameters by looking at where they are referenced in the source code you have.
The current programming paradigm is to skip documentation for the most part unless its going to be used by a lot of people. Instead they will embed comments that give you a hint of what they are used for.
temp is the temperature at which to sample and if chainno is 1 then it will use 1 cpu, or you can set it to a different number.
I tried but not luck. I have find this MrBayes (sourceforge.net)
I guess I have 2 cores but I am setting chains = 4 and temp = 0.2 it seems to be working.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
