Xinthose
- 10
Create a Mealy Edge Detector, then measure the pulse width of 75 micro seconds by 50 MHz clock; here is the timing diagram:
I am basically trying to emulate this diagram in my test fixture code (using Xilinx 14.1 in Verilog) and am having errors. Also, the tick is supposed to be a push button on my FPGA Board I think; any help would be greatly appreciated as my professor won't help me. The book doesn't help and he tells me to just figure it out, so that is what I am trying to do here. Where you see my clock there, that is my attempt at making it alternate like in the picture, I don't know how to do it.
Code:
module Homework_3_Mealy_Edge_Detector_TF;
// Inputs
reg clk;
reg reset;
reg level;
integer i;
// Outputs
wire tick;
// Instantiate the Unit Under Test (UUT)
Homework_3_Mealy_Edge_Detector uut
.clk(clk),
.reset(reset),
.level(level),
.tick(tick)
initial
begin
clk = 1'b0;
#100;
end
begin
for(i = 0; i < 8; i = i + 1)
begin
level = 1'b0; // ERROR MESSAGE
if (level)
begin
#300;
end
else
begin
level = 1'b1;
#300
end
end
begin
clk = 1'b0;
if (clk)
begin
clk = 1'b0; // ERROR MESSAGE
#100;
end
else
begin
clk = 1'b1;
#100
end
end
end
endmodule
also, here's the behavioural model if you're interested, it gives no errors (it's straight from the book)
Code:
input wire clk, reset,
input wire level,
output reg tick
// symbolic state declaration
localparam zero = 1'b0,
one = 1'b1;
// signal declaration
reg state_reg, state_next;
//state register
always @(posedge clk, posedge reset)
if (reset)
state_reg <= zero;
else
state_reg <= state_next;
// next-state logic and ouput logic
always @*
begin
state_next = state_reg; // default state: the same
tick = 1'b0; // default output: 0
case (state_reg)
zero:
if (level)
begin
tick = 1'b1;
state_next = one;
end
one:
if (~level)
state_next = zero;
default: state_next = zero;
endcase
end
endmodule
