MHB Mean and standard deviation and probability
The discussion revolves around calculating the mean and standard deviation for a sample of systolic blood pressure among women aged 18-24, which is normally distributed with a mean of 114.8 and a standard deviation of 13.1. The correct mean and standard deviation for the sample of 100 women is 114.8 and 1.31, respectively, as the standard deviation of the sample mean is calculated using the formula σ/√n. For the probability that the mean systolic blood pressure is between 112.2 and 116.4, participants are guided to use the Z-score formula for normal distributions. The discussion emphasizes understanding sampling distributions and the application of probability concepts. This foundational knowledge is crucial for solving similar statistical problems effectively.
tcardwe3
I did the problem but none of my answers match up with the answer choices so I'm obviously doing it wrong. Can someone show me how to do these two problems. I have a test coming up and I am so behind
For women aged 18-24, the systolic blood pressure (in hg mm) are normally distributed with a mean of 114.8 and a standard deviation of 13.1
100 women between 18 and 24 are randomly selected, let t represent the systolic pressure of 100 women
-Find the mean and standard deviation of t
a) 114.8, 131
b) 114.8, 13.1
c) 114.8, 1.31
d) 11.48, 1.31
d) 11.48, 1.31
-What is the probability that the mean systolic blood pressure t is between 112.2 and 116.4
a) .8649
b) .3879
c) .1578
d) .571
e) .0324
Mathematics news on Phys.org
[box=red]
Sampling Distribution of a Normal Variable
Given a random variable $$X$$. Suppose that the population distribution of $$X$$ is known to be normal, with mean $\mu$ and variance $\sigma^2$, that is, $X\sim N(\mu,\sigma)$. Then, for any sample size $n$, it follows that the sampling distribution of $X$ is normal, with mean $\mu$ and variance $\dfrac{\sigma^2}{n}$, that is, $\overline{X}\sim N\left(\mu,\dfrac{\sigma}{\sqrt{n}}\right)$[/box]
Based on this, what would you say the correct answer to the first part of the problem is?
For the second part of the question.
$\displaystyle P\left(112.2<\bar{T}<116.4\right) = P\left(\frac{112.2-\mu}{\frac{\sigma}{\sqrt{n}}}<Z<\frac{116.4-\mu}{\frac{\sigma}{\sqrt{n}}}\right)= \cdots$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
