MHB Mean and variance from a probability distribution function
The discussion focuses on finding the mean and variance of a given probability distribution function, which is defined for 0<x<∞. Participants express confusion over the notation in the function and clarify that the correct probability density function (pdf) is f(x) = (2/√(2π)) e^(-x²/2) for 0<x<∞. To compute the expected value E[X] and E[X²], they suggest using integrals and comparing E[X²] with the variance of the standard normal distribution N(0, 1). The conversation emphasizes the importance of understanding the integral calculations involved in determining the mean and variance.
fred1
f(x)=f(x)={█(2/(√2π) e^(〖-x〗^2/2)@0 otherwise)┤for 0<x<∞
Find the mean and variance of X
The hint says, compute E(X) directly and then compute E(X2) by comparing that integral with the integral representing the variance of a variable that is N (0, 1)
Hello fred,
I find the probability distribution function, as given, hard to interpret, and the attached file does not help me.
What do the symbols "@0" and "┤" mean?
I'm making an educated guess with this, but is this the pdf?
\[f(x)=\begin{cases} \frac{2}{\sqrt{2\pi}} e^{-x^2/2} & 0<x<\infty\\ 0 & \text{otherwise}\end{cases}\]
I would recommend that you look at our LaTeX help subforums for learning how to use LaTeX on our forums.
Anyways, if that's the proper pdf, then you have that
\[E[X] = \int_{-\infty}^{\infty} xf(x)\,dx\quad\text{and}\quad E[X^2]=\int_{-\infty}^{\infty}x^2f(x)\,dx\]
Furthermore, they want you to evaluate $E[X^2]$ by comparing it to the variance integral for $\mathcal{N}(0,1)$. Since the pdf of $\mathcal{N}(0,1)$ is
\[f(x)=\frac{1}{\sqrt{2\pi}} e^{-x^2/2}\]
and since we know that $E[X]=0$, we have that
\[1=\text{Var}[X]=E[X^2]-(E[X])^2=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{\infty}x^2e^{-x^2/2}\,dx\]
Thus, to evaluate $\displaystyle\int_{-\infty}^{\infty} x^2f(x)\,dx$, you'll need to use the fact that $\displaystyle\int_{-\infty}^{\infty} x^2e^{-x^2/2}\,dx = \sqrt{2\pi}$.
I hope this helps!
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
