Mean energy of system with ## E = \alpha |x|^n ##
In summary, the problem involves finding the average energy of a system with energy behavior modeled by ##E = \alpha |x|^n##, where ##n = 1, 2, 3, \dots## and ##\alpha > 0##. The solution involves using integrals and taking a partial derivative, but the integral itself is difficult to solve.
Dazed&Confused
191
If the energy ##E## of a system behaves like ## E = \alpha |x|^n##, where ## n =1, 2, 3, \dots ## and ## \alpha > 0##, show that ## \langle E \rangle = \xi k_B T ##, where ##\xi## is a numerical constant.
$$ \langle E \rangle = \frac{ \int_{- \infty}^{ \infty} Ee^{-\beta E}}{\int_{-\infty}^{ \infty} e^{-\beta E}},$$ where ## \beta = \frac{1}{k_BT}.##
Since the integral is even, it can be written as $$\frac{ \int_{0}^{ \infty} \alpha x^n e^{-\beta \alpha x^n}}{\int_{0}^{ \infty} e^{-\beta \alpha x^n}},$$
It can also be written as
$$ \frac{ \frac{ \partial}{ \partial \beta} \left ( \int_{0}^{ \infty} - e^{-\beta \alpha x^n} \right ) } {\int_{0}^{ \infty} e^{-\beta \alpha x^n}}$$
where the partial derivative was taken outside the integral.
I have no idea how to solve the integral. Mathematica didn't draw up anything useful.
Have you tried a change of variable e.g. y=xn?
I think I did try it, but it didn't look like it could result in anything useful.
Related to Mean energy of system with ## E = \alpha |x|^n ##
What is the definition of mean energy of a system?
The mean energy of a system refers to the average energy value for all particles or components within the system. It is calculated by taking the sum of all individual energy values and dividing it by the total number of particles or components in the system.
How is the mean energy of a system with a given equation calculated?
The mean energy of a system with a given equation, such as ## E = \alpha |x|^n ##, is calculated by plugging in the values of ## \alpha ## and ## n ## and using the formula for mean energy. This may also require taking into account any other variables or constants that may affect the energy of the system.
Why is the mean energy of a system important in scientific research?
The mean energy of a system is important in scientific research because it can provide valuable insights into the behavior and properties of the system. It can also help in predicting and understanding the effects of different variables on the system's energy and overall behavior.
How does the mean energy of a system change with different values of ## \alpha ## and ## n ##?
The mean energy of a system can vary depending on the values of ## \alpha ## and ## n ##. For example, increasing the value of ## \alpha ## will result in a higher mean energy, while increasing the value of ## n ## will result in a lower mean energy. The exact relationship between these variables and the mean energy will depend on the specific equation of the system.
Can the mean energy of a system be negative?
Yes, the mean energy of a system can be negative. This can happen if the system has a combination of positive and negative energy values, resulting in an overall negative mean energy. However, this is not always the case and the mean energy of a system can also be positive or zero, depending on the specific equation and values of variables.
  • Quantum Physics
