Mean free path and effective collision radius
In summary, the beam of silver atoms passing through air at a temperature of 273K and a pressure of 1 Pa is attenuated by a factor of 2.72 in a distance of 10^-2 m. Using the probability of collision, the mean free path of the silver atoms is calculated to be 0.01m, which may seem large due to the low density of air. The effective collision radius is estimated to be 2.91 x 10^-10 m using the formula pi r^2 = collision cross section.
bon
559
Beam of silver atoms are passing through air at a temp 273K and a pressure of 1 Pa. The beam is attenuated by a factor of 2.72 in a distance of 10^-2 m. Find the mean free path of the silver atoms and estimate the effective collision radius..
Ok so taking the probability of the collision between x and x+dx to be 1/a e ^-1/a x where 1/a is the mean free path, i worked it out to be 0.01m...but this seems huge? Why should it be about 1 cm?
Also, to work out the effective collision radius, do i just use pi r^2 = collision cross section (usually denoted by sigma), where r is the effective collision radius?... I get this to be about 2.91 x 10^-10 m...but is this right?
All of the above looks right. Remember air isn't very dense, so silver atoms can have a pretty large mean free path.
Related to Mean free path and effective collision radius
1. What is the mean free path?
The mean free path (MFP) is the average distance a particle travels between collisions with other particles in a gas or liquid. It is a measure of how far a particle can travel before it is likely to collide with another particle.
2. How is the mean free path calculated?
The mean free path can be calculated using the formula: MFP = (1/√2πd^2n), where d is the diameter of the particle and n is the number of particles per unit volume. This equation assumes that the particles are small and spherical and that they are evenly distributed throughout the medium.
3. What factors affect the mean free path?
The mean free path can be influenced by several factors, including the size and shape of the particles, the temperature and pressure of the medium, and the presence of other particles or impurities in the medium. In general, as the number of collisions increases, the mean free path decreases.
4. What is the effective collision radius?
The effective collision radius is the distance at which two particles must be to interact with each other. It is determined by the size and shape of the particles, as well as the strength of the interactions between them. A smaller effective collision radius means that particles are more likely to collide with each other.
5. How are the mean free path and effective collision radius related?
The mean free path and effective collision radius are inversely proportional to each other. This means that as the mean free path increases, the effective collision radius decreases, and vice versa. This relationship is important in understanding how particles move and interact in a gas or liquid medium.
