Mean nearest neighbor distance in 3d
In summary: Therefore, the average distance between star systems in the solar neighborhood is approximately 3.93 light years.In summary, the conversation discusses the average distance between nearest neighbors in a randomly distributed sample of particles in 3-dimensional Euclidean space. The formula for this distance is given as d_nearest neighbor_mean=(volume/n)^1/3 where n particles are randomly distributed in a 3 dimensional volume. The question of the average distance between stars in the solar neighborhood is also explored, with a formula of 6.16 LY being calculated. A solution is proposed that gives an average distance of 3.8 LY, and the conversation ends with a discussion
trekkiee
Hi. In 3 dimensional Euclidean space with the usual metric, d=[(delta x)^2+(delta y)^2+(delta z)^2]^1/2, I'm trying to figure out the average distance between nearest neighbors in a randomly distributed sample of particles. My best initial guess for the average distance from any given particle to its nearest neighbor is d_nearest neighbor_mean=(volume/n)^1/3 where n particles are randomly distributed in a 3 dimensional volume.
The question originated when I wondered what was the average distance between stars in the solar neighborhood. atlasoftheuniverse.com gives 35 stars (including the Sun) within 12.5 light-years, and the above formula yields 6.16 ly as the avg distance from any given star to its closest neighbor. This seemed a little high to me, since the distance from the Sun to its nearest neighbor (Proxima Centauri) is 4.4 ly. But perhaps the Sun has a closer-than-avg nearest neighbor, since, after all, the distribution should be very close to random. Let us assume that the stars are randomly distributed.
I originally thought it would be easy to figure this out, but after trying unsuccessfully for an hour to work out a better formula, then another hour trying to google one, I gave up. Thanks in advance :)
Mathematics news on Phys.org
If there are 35 stars within 12.5 LY of the sun, and Proxima Centaurii is the closest at 4.4 LY, it's not at all surprising that you got a mean distance of 6.16 LY. All of these stars are distributed between 4.4 LY and 12.5 LY, so if there are distributed uniformly or normally, the mean distance would certainly be somewhere between the extreme values.
interesting problem. Did you make this up on your own, or is it a textbook problem?
Here's an solution that gives you an average distance of 3.8 ly.
Let's say that each piece of volume dV has an equal probability of containing a star. And let n be the number of stars in the total volume of interest V, so that the density function is just (n/V). And the average number of stars in a chosen volume v about some center point is just v(n/V). Then you're looking for the volume v at which the expected number of stars in the volume v is exactly 1. This is true when v = (V/n). Solving for r (v = (4/3)pi*r^3 ), then
r = [ (3V) / (4*pi*n) ] ^ (1/3)
I found V and n from your numbers (35 stars within 12.5 ly, so n=35, v = (4/3)*pi*12.5^3 =8181 ly^3 ), and then calculated r to be 3.8. So you would expect to find your first star within 3.8 ly of any chosen point, though the actual distance will vary about 3.8 ly.
Modest at
http://hypography.com/forums/physics-mathematics/21509-mean-nearest-neighbor-distance-3d.html
was helpful in pointing me to this link:
http://books.google.com/books?id=hp...n a random distribution of particles"&f=false
And now I need to integrate:
integral of x^3 exp(-a x^3) dx, with a = constant,
but I couldn't. Hopefully, it's an easy integral and and someone will figure it out.
In a 3-dimensional random distribution, the basic idea for finding the average distance from any given particle to its nearest neighbor begins with:
P(r)dr = [1 - integral from 0 to r of P(r)dr][4 pi r^2 pho dr] (1)
where
pho = average number of particles/unit volume
P(r) dr = the probability of a particle's nearest neighbor occurring in the interval [r,r+dr]
integral from 0 to r of P(r) dr = probablity that an arbitrary particle's nearest neighbor lies within a distance r of the particle
1 - integral from 0 to r of P(r) dr = the probability that the nearest neighbor is no closer than r.
differentiating & separating eq. 1:
dP/P = [2/r - 4 pi rho r^2] dr
integrating:
P = [constant] r^2 exp(- [4/3] pi rho r^3)
normalizing:
1 = integral from 0 to infinity of P(r) dr
1 = [constant] integral from 0 to infinity of r^2 exp(-[4/3] pi rho r^3) dr
1 = [constant] [-[1/(4 pi rho)] exp(-[4/3] pi rho r^3)] evlauated from 0 to infinity
gives the constant = 4 pi rho and P(r) = 4 pi rho r^2 exp(-[4/3] pi rho r^3)
The average distance from any given particle to its nearest neighbor in 3 dimensions is then the expectation value of r:
<r> = integral from 0 to infinity of r P(r) dr
<r> = [4 pi rho] [integral from 0 to infinity of r^3 exp(-[4/3] pi rho r^3) dr]
I was unable to do the last integral, but I'm sure someone can :)
I wonder what it means "35 stars in the 12.5 ly radius". It means either 35th star is 12.5 ly from us, or 36th start is at this distance - or anything in between.
I am going to look at the 2D derivation the Modest showed us, ASAP.
Until then, note that my previous solution is probably very slightly off, though I'm not yet sure why. By my reasoning, for the 2D nearest neighbor distance problem I would say that we are looking for the value of r for which rho*(pi*r^2) =1.0, aka <r> = 1/ (pi*rho)^.5 , where rho is the average density. This is 0.564/(rho^.5), remarkably close to the given 2D solution of .5/(rho^.5). Interesting!
When we solve the 3D problem, we can see how close my answer is (I said <r> = [(3/4)*(1/pi)*(1/rho)]^1/3 , where rho is the 3D avg density...this actually gives <r> = 0.621/(rho^1/3))
It will be interesting to see if your integral gives something close to 0.621 / (rho^1/3)
since what we really want is the average distance to the nearest star system, and atlasoftheuniverse.com reports 23 star systems within 12.5 ly (35 stars but 3 trinaries, 6 binaries, and 14 singles), we have:
rho = 23/([4/3]pi 12.5^3)
rho = 0.0028113 star systems/cubic light-year
rho is only an estimate since some of the star systems near the outer edge of the volume (of 12.5 ly radius) might have nearest neighbors outside the volume and some star systems just outside the volume might have nearest neighbors inside.
since the integral of x^3 exp(-a x^3)dx doesn't seem to be integrable, I used
http://people.hofstra.edu/stefan_waner/RealWorld/integral/integral.html
to numerically integrate:
the integral from 0 to infinity of 0.035328(x^3)(e^(-0.011776(x^3)))dx = 3.93 light years
as the average distance from an arbitrary star system in the solar neighborhood to its nearest nighbor :)
Good stuff.
Based on the new approach of star systems, which gives rho = 0.002811, my equation gives 4.396 ly.
This is extremely close to 4.4 ly, the value you gave as the distance from our sun to Proxima Centauri. This is probably nothing more than statistical coincidence.
Do you think that for suitably large volumes and # of stars, my approach is correct?
Basically all I am saying mathematically is that if we model the position of stars as roughly independent (which I believe your model also does), then the number of stars in a volume should be proportional to that volume. I find <r> geometrically using the volume at which the expected number of stars equals exactly 1.0.
frustr8photon said:
Good stuff.
I'm not sure but I think the problem with your approach is:
1. There are 2 star systems within your control volume; the system at the center and the nearest system.
2. your volume as stated doesn't need to be centered on an arbitrary star system, but can be centered at any point. Perhaps you are finding the minimun volume within the region that contains 1 star system.
aswoods at
www.sosmath.com/CBB/viewtopic.php?p=197769#197769
helpfully pointed out that Gradshteyn and Ryzhik 3.381.10, and Wolfram Alpha agree that
the integral from 0 to infinity of x^3 e^(-ax^3)dx = 1/3 gamma(4/3) a^(-4/3)
so the mean nearest neighbor distance in 3d is:
<r> = [4 pi rho] integral from 0 to infinity r^3 e^(-[4/3] pi rho r^3) dr
<r> = 1/3 gamma(1/3) ([4/3] pi)^(-1/3) rho^(-1/3)
<r> = 0.55396 rho^(-1/3)
<r> = 3.93 light-years for the 23 star systems within 12.5 ly :)
trekkiee said:
I'm your volume as stated doesn't need to be centered on an arbitrary star system, but can be centered at any point. Perhaps you are finding the minimun volume within the region that contains 1 star system.
or the mean minimum volume within the region that contains at least 1 star system
trekkiee said:
Modest at
where
integrating:
normalizing:
I guess a more correct derivation of expected distance to nearest star should imply integration up to a formal radius Rmax, regarding increased density between r and Rmax
due to no star found up to that r. So density reaches infinity at Rmax, for instance. I.e the same derivation procedure, but regarding this theoretically increased density in formuas.
And first afterwards letting Rmax reach infinity. Likely it doesn't change end result, but
theoretically that compression during integration should be regarded.
I may return with a complete derivation regarding this.
Here I am again. (The "LaTex" symbol routine for some reason only shows black background to me last time, why I must use simple typing). :mad:
I assume a formal max radius Rmax instead of directly up to infinity. That also makes the solution easier. But instead of using radius , I use corresponding volume v upp to Vmax.
Definitions: V = max volume (corresponding to Rmax). v = temporary volume (corresponding to r). N = Number of stars inside V. C = star density = N / V.
Density outside v is c(v) = C V / (V-v)
Likelihood a star is not inside v, i.e. in shell between v and V, is (V-v)/V . Implies likelihood all stars outside v is [(V-v)/V] exp CV = Q(v). (Not that easily derived if V was directly put infinite).
Expected v* for first met star is Integral {v = 0 to V} of [Q(v) c(v)] v dv , where [Q(v) c(v)] is weight factor - who's integral {v= 0 to V} is shown = 1 and therefore already normalized.
The "Primitive Function" F turns out to be -[v + (V-v)/(CV+1)] [1-(v/V)} exp CV
and searched v* = F(V) - F(0) = 1 / (C + 1/V)
Lim v* (V approach infinity) is 1/C according to earlier results here. I.e expected nearest distance 3.8.. LY . :approve:
Related to Mean nearest neighbor distance in 3d
1. What is the mean nearest neighbor distance in 3D and why is it important?
The mean nearest neighbor distance in 3D is a measure of spatial patterns in a three-dimensional space. It is the average distance between a point and its nearest neighboring point. This measure is important because it can help to identify whether there is clustering or dispersion of points within a given space, which can have important implications for understanding ecological processes.
2. How is the mean nearest neighbor distance calculated in 3D?
The mean nearest neighbor distance in 3D is calculated by dividing the sum of the distances between each point and its nearest neighbor by the total number of points. This can be done using mathematical formulas or through spatial analysis software.
3. Can the mean nearest neighbor distance in 3D vary depending on the size of the study area?
Yes, the mean nearest neighbor distance in 3D can vary depending on the size of the study area. This is because as the study area increases, the number of points and their relative distances also increase, which can affect the overall average distance between nearest neighbors. Therefore, it is important to consider the size of the study area when interpreting the results of this measure.
4. How is the mean nearest neighbor distance used in ecological studies?
The mean nearest neighbor distance is often used in ecological studies to assess the spatial patterns of species or populations. It can help to identify whether there is clustering or dispersion of individuals, which can provide insight into ecological processes such as competition, dispersal, and habitat selection. This measure can also be used to compare spatial patterns between different study sites or over time.
5. Are there any limitations to using the mean nearest neighbor distance in 3D?
Yes, there are some limitations to using the mean nearest neighbor distance in 3D. This measure assumes that all points are equally likely to occur in any location within the study area, which may not always be the case in ecological studies. Additionally, the results can be affected by the presence of outliers or uneven distribution of points. Therefore, it is important to consider these limitations when interpreting the results of this measure.
  • Linear and Abstract Algebra
  • Astronomy and Astrophysics
