Mean value of momentum of electron in H atom
In summary, the mean value of momentum of an electron in a hydrogen atom is related to its energy and is affected by changes in the atom's energy levels. It cannot be negative and may change over time, but is a conserved quantity. It is given by the equation p = nh/λ and is directly related to energy through the equation E = (p^2 / 2m) - (ke^2 / r).
superyoon
What is the mean value of the momentum of an electron of a hydrogen atom in its ground state? Derive this mean value of the momentum from the kinetic energy of the electron.
<p> = integral from -infinity to infinity (p*|psi|^2) dx
p^2/2m = KE
I solved the equation above for p; p = sqrt(2m*KE). <p> = integral from -infinity to infinity [sqrt(2m*KE)*|psi|^2]dx, but I don't know where to go from here.
Thanks.
FAQ: Mean value of momentum of electron in H atom
What is the mean value of momentum of an electron in a hydrogen atom?
The mean value of momentum of an electron in a hydrogen atom is given by the equation p = nh/λ, where n is the principle quantum number, h is Planck's constant, and λ is the wavelength.
How is the mean value of momentum of an electron in a hydrogen atom related to its energy?
The mean value of momentum of an electron in a hydrogen atom is directly related to its energy through the equation E = (p^2 / 2m) - (ke^2 / r), where m is the mass of the electron, ke is Coulomb's constant, and r is the distance between the electron and the nucleus.
Can the mean value of momentum of an electron in a hydrogen atom be negative?
No, the mean value of momentum of an electron in a hydrogen atom cannot be negative. It is a vector quantity with direction, but its magnitude is always positive.
How is the mean value of momentum of an electron in a hydrogen atom affected by changes in the atom's energy levels?
The mean value of momentum of an electron in a hydrogen atom changes with the energy levels of the atom. As the electron moves to a higher energy level, its momentum increases, and as it moves to a lower energy level, its momentum decreases.
Is the mean value of momentum of an electron in a hydrogen atom constant over time?
No, the mean value of momentum of an electron in a hydrogen atom can change over time as the electron moves and interacts with other particles. However, it is a conserved quantity, meaning that the total momentum of the electron will remain constant in a closed system.
