Meaning and use of the Ackermann's function
  • MHB
  • Thread starter mathmari
  • Tags
    Function
In summary, the Ackermann function is a total function that is not primitive recursive and is closely related to Knuth's up-arrow notation. It extends the hierarchy of addition, multiplication, and exponentiation. Ackermann function can be defined as a recursive function on type $\Bbb N\to\Bbb N$, showing that recursion on higher types is more powerful. It is also interesting to note that there are total functions that cannot be defined by primitive recursion in all finite types, providing an example of an arithmetic statement that is true but not provable in arithmetic.
mathmari
MHB
5,049
Hey! :eek:
Could you tell me which the meaning of the Ackermann's function is for the theoretical computer science?? (Wondering)
And which is its use?? (Wondering)
Ackermann function is probably the simplest (and maybe historically first) example of a total function that is not primitive recursive, as your other thread discusses. It is also closely related to Knuth's up-arrow notation. The idea of this notation is very natural:
  • addition is a repeated addition of 1
  • multiplication is repeated addition
  • exponentiation is repeated multiplication
This list can be continued by making the function at level $k+1$ to be repeated application of function at level $k$.
If $f$ is a function of two arguments. let $f\,x$ denote the function of one argument obtained from $f$ by fixing the first argument to $x$. This is often denoted by $f(x,\cdot)$. In general, if a function has $k$ argument and $i<k$, then the first $i$ arguments can be fixed to obtain function of the rest $k-i$ arguments. Similarly, if $\star$ is a binary operator, then $(x\star{})$ or $({}\star x)$ is a function of one argument obtained by fixing the first (respectively, the second) argument to $x$. This is called currying in computer science. If $g$ is a function of one argument, then $g^n$ is $n$-fold composition of $g$: $g^n(x)=g(g(\dots g(x)\dots))$ ($g$ is used $n$ times). Then the list of functions above can be written as follows.
\begin{align}
m+n&=(1+{})^n(m)&&\\
m\cdot n&=(m+{})^n(0)\\
m^n&=(m\cdot{})^n(1)
\end{align}
Knuth suggested extending this sequence by calling subsequent functions $\uparrow$, $\uparrow\uparrow=\uparrow^2$, $\uparrow\uparrow\uparrow=\uparrow^3$, …
\begin{align}
m\uparrow n=m^n&=(m\cdot{})^n(1)\\
m\uparrow^2 n&=(m\uparrow{})^n(1)\\
m\uparrow^3 n&=(m\uparrow^2{})^n(1)\\
\end{align}
and in general
m\uparrow^{k+1}n=(m\uparrow^k{})^n(1)
This can be extended to level 0 by $m\uparrow^0 n=mn$. The reason $\uparrow$ corresponds to exponentiation and not, say, to addition, is probably that $\uparrow$ looks like ^, which is used to type exponentiation in TeX. Also, the base case is different in addition and multiplication and becomes 1 only starting with exponentiation. However, we could define the function
\operatorname{base}(k,m)=
\begin{cases}
m&k=-1\\
0&k=0\\
1&k>0
\end{cases}
and then define
\begin{align}
m\uparrow^{-2} n&=n+1\\
m\uparrow^{k+1}n&=(m\uparrow^k{})^n(\operatorname{base}(k+1,m))&&k\ge-2
\end{align}
to extend the hierarchy to include successor, addition and multiplication.
Note that Ackermann function can be defined as
\begin{align}
A(0,n)&=n+1\\
A(k+1,n)&=(A\,k)^n(A(k,1))
\end{align}
From this it should be possible to prove, as Wikipedia claims, that
A(k,n)=2\uparrow^{k-2} (n+3) - 3.
So Ackermann function is not just some function defined by weird recursion, but is closely related to the hierarchy of addition, multiplication, exponentiation and so on.
It is interesting to meditate on the immensity of a number like $3\uparrow\uparrow\uparrow\uparrow4$, compared to which the number of particle in the universe is nothing. This is discussed in Knuth's book Things a Computer Scientist Rarely Talks About.
If one considers lambda calculus, then it can be shown that Ackermann function can be defined by recursion on type $\Bbb N\to\Bbb N$ (whereas primitive recursive functions are defined by recursion on $\Bbb N$). This shows that recursion on higher types is more powerful. In fact, functions defined by primitive recursion in all finite types are those about which first-order arithmetic can prove that they terminate. And even then there are total functions that cannot be defined by primitive recursion in all finite types: they provide an example of an arithmetic statement that is true, but not provable in arithmetic in the spirit of Gödel's incompleteness theorem.
I would recommend consulting the Wikipedia article, which seems pretty good, and links therein.
Edit: Switched $({}\uparrow^k m)^n(1)$ to $(m\uparrow^k{})^n(1)$ and similarly in other places. The previous version was incorrect. Thus, $({}\uparrow m)^n(1)=1$, but $(m\uparrow{})^n(1)={m_{{}}^{{m^{{{}^{{.\,^{{.\,^{{.\,^{m}}}}}}}}}}}}$.
FAQ: Meaning and use of the Ackermann's function
What is the Ackermann's function and why is it important?
The Ackermann's function is a mathematical function that was created by Wilhelm Ackermann in 1928. It is an important function in the field of computability and is used to demonstrate the difference in complexity between different types of functions.
How is the Ackermann's function defined?
The Ackermann's function is defined recursively as A(m, n) = n + 1, if m = 0; A(m - 1, 1), if m > 0 and n = 0; A(m - 1, A(m, n - 1)), if m > 0 and n > 0. This means that the function takes two non-negative integers as inputs and returns another non-negative integer as the output.
What is the time complexity of the Ackermann's function?
The Ackermann's function has a very fast growing time complexity. In fact, it grows faster than any computable function. As the inputs increase, the number of steps required to calculate the function increases exponentially, making it an extremely time-consuming function for large inputs.
Can the Ackermann's function be used in real-world applications?
The Ackermann's function is mainly used in theoretical computer science and is not commonly used in real-world applications. However, it has been used in some programming languages as a test for recursion and to demonstrate the limits of computation.
Are there any practical uses for the Ackermann's function?
While the Ackermann's function may not have direct practical uses, it has been used in the development of algorithms and data structures. It has also been used to analyze the efficiency of different algorithms and to understand the limits of computability.
