- #36
PeterDonis
Mentor
- 46,755
- 23,268
PAllen said:It seems we have explored this topic before, in a thread I forgot all about
So had I. Thanks for digging it up!
PAllen said:if you have a congruence orthogonal to a foliation, why can't you then diagonalize the 3-manifolds of the foliation, and then build the 4th basis as the surface orthogonal congruence tangent, and end up with coordinates everywhere orthgonal?
This is an interesting question, because that's pretty much what you're doing in FRW spacetime to construct the standard FRW chart, and it works. The key difference in Kerr spacetime is that the 3-manifolds in question have only one spacelike KVF (the axial one), whereas the ones in FRW spacetime have six. In that other thread we had proposed that maybe there is some minimum number of spacelike KVFs that the 3-manifold has to have for the method you describe to produce a diagonal line element. (The number we proposed was three, since that's how many Schwarzschild spacetime has, and your method works for that spacetime.)
To put what I just said another way, consider how the "direction" in spacetime of the 4th basis vector changes as we move through the 3-manifold. In FRW spacetime, the change is isotropic; it's the same if we move in any direction in the 3-manifold. In Kerr spacetime, the change is not isotropic. This anisotropy (which I'm sure there's a slicker way of describing, perhaps in terms of the extrinsic curvature of the 3-manifold as embedded in spacetime) might be the reason there has to be at least one cross term in the line element.
