Agerhell
- 157
- 2
According to the Schwarzschild solution in the most common anisotropic (Schwarzschild?) coordinates the proper time and the coordinate time are related as:
[tex]\frac{dt}{d\tau}=\frac{1}{\sqrt{1-\frac{2GM}{rc^2}-\frac{|\bar{v}\times\hat{r}|^2}{c^2}-\frac{1}{1-\frac{2GM}{rc^2}}\frac{(\bar{v}\cdot\hat{r})^2}{c^2}}}[/tex]
Now as i read on wikipedia, quote:
I interpret this as that the velocity of light (in coordinate time)according to the Schwarzschild solution in Schwarzschild coordinates is different in different directions and that the velocity of light is: [tex]c_{coordinate}=c(1-\frac{2GM}{rc^2})[/tex] vertically and [tex]c_{coordinate}=c\sqrt{1-\frac{2GM}{rc^2}}[/tex] horizontally. Correct?
Now, according to wikipedia you can transform to isotropic coordinates to get the speed of light to be the same in all directions. What set of coordinates corresponds to the real physical situation? Is the speed of light isotropic in a gravitational field or is it not?
I am trying to set up an expression for ##\frac{d\bar{v}}{dt}## that is supposed to produce planetary orbits similar to what is exptected from the Schwarzschild solution. To check my expression I must compare with the variant of the Schwarzschild solution with coordinates that correspond to the real life situation. Which set of coordinates is that?
"The original form of the Schwarzschild metric involves anisotropic coordinates, in terms of which the velocity of light is not the same for the radial and transverse directions (pointed out by A S Eddington). Eddington gave alternative formulations of the Schwarzschild metric in terms of isotropic coordinates"
