Meaning of Single Photon Interference Minima
In summary: The wave function is a mathematical description of the particle, and it tells us a lot about its properties such as its momentum and energy.
LikesIntuition
51
In the double slit experiment, when we send out one photon at a time, what does the appearance of minima in our interference pattern mean? When a single photon is fired, I understand (using "understand" very loosely) that the photon will interfere with itself. When this happens, does it still have to land on the wall in front of the slit and it is limited to the bright bands defined by interference, or are there times where we will fire the photon and it will destructively interfere with itself and we won't see it land on the wall? Because if that's the case, energy would just be disappearing.
I can try to clarify if need be.
Thanks!
It means that there are regions where the probability of detecting the photon is very low.
In an idealized experiment, the probability of detecting the photon must be one. It is the probability amplitude (i.e., the wave function) that will show areas of constructive or destructive inteference. It is not the photon interfering with itself.
The interference pattern redistributes the photons (and the energy that they carry) so that there are more of them in the maxima and fewer of them in the minima, than we would expect if there were no interference. No photons or energy "disappear".
Alright, so every time we send a photon through the double slit, we will detect one after the slit? And it's two wave functions describing the photon as it moves through each slit that interfere with each other?
If that's the case, what's the difference between talking about the photon and it's wave function?
Well actually, without going into the details, you don't have a wave-function for photons.
But the double slit can be done with electrons so let's consider that instead.
The wave-function encodes all the quantum properties of the electron.
Also you may like to see an actual quantum explanation of the double slit:
http://cds.cern.ch/record/1024152/files/0703126.pdf
Interestingly it hasn't really got anything to do with waves.
Thanks
Bill
In the double-slit experiment, when you fire one photon you get one spot on the photographic film behind the slits. You'll say that one spot is where the particle hit, and we're talking about the particle not the wave function.
As you fire more photons more spots on the film will appear; these spots will gradually build up a pattern of dark and light regions corresponding to the areas of constructive and destructive interference. Now we're talking about the wave function.
Related to Meaning of Single Photon Interference Minima
1. What is a single photon interference minima?
A single photon interference minima is a phenomenon that occurs when a single photon is passed through a double-slit apparatus, resulting in an interference pattern on a screen behind the apparatus. The minima refer to the dark areas of the pattern where the photons have cancelled each other out due to destructive interference.
2. How is single photon interference minima different from classical interference?
In classical interference, the interference pattern is created by the superposition of multiple waves. However, in single photon interference minima, the interference pattern is created by the interference of a single photon with itself. This is due to the wave-particle duality of light, where photons behave as both particles and waves.
3. What is the significance of single photon interference minima?
Single photon interference minima have significant implications in the field of quantum mechanics. They demonstrate the wave-particle duality of light and provide evidence for the probabilistic nature of quantum systems. They also have practical applications in technologies such as quantum cryptography and quantum computing.
4. How are single photon interference minima observed?
To observe single photon interference minima, a double-slit apparatus is set up with a single photon source and a screen behind it. The photons are then passed through the apparatus one at a time, and the resulting interference pattern is observed on the screen. The pattern will show areas of both bright and dark fringes, with the dark fringes representing the minima.
5. Can single photon interference minima be observed with other particles?
Yes, single particle interference can be observed with other particles, such as electrons and even large molecules. This further supports the wave-particle duality of matter and provides evidence for the probabilistic nature of quantum systems. However, the interference pattern becomes less pronounced as the size and mass of the particles increase.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
