SiennaTheGr8
- 493
- 193
PeroK said:If you have a system of equal mass particles, then in Newtonian physics conservation of momentum implies conservation of total velocity.
I'm reminded of something that I'd be curious to get some thoughts on.
There's a semantic issue with the word "conserved" that often flies under the radar: does the term refer to any quantity whose value remains the same before and after some process, or does it specifically refer to an additive quantity that fits that bill? Usage is inconsistent in the literature (I can dig up examples if I'm asked).
To make matters worse, there's also an inconsistency in what is meant by "the mass of a system"—some define it as the sum of the masses of the system's constituents, and some define it as the system's rest energy (expressed in mass units). The latter is more common, thankfully, but I'm sure I could provide an instance or two of the former.
When you put all these various usages together, you end up with a mess of possible answers to the question is mass conserved in SR? (and this is without even opening the "relativistic mass" can of worms!):
- The word "conserved" simply isn't applicable to quantities that aren't additive.
- The mass of an isolated system is not necessarily conserved because various internal processes can cause the sum of the constituent masses to change.
- The mass of an isolated system is conserved as a trivial consequence of energy-conservation (i.e., energy is conserved for any frame, including the system's rest frame).
I once tried to point all this out to some knowledgeable people on another forum, but they were... not receptive.
