Measurability of Open Sets in [0,1]
  • MHB
  • Thread starter Fermat1
  • Tags
    Sets
In summary: So yes, you can conclude that $(a,b)$ is measurable.In summary, to show that an open set in [0,1] is measurable, given that [0,x] is measurable for each x in [0,1], we need to show that (a,b) is measurable. Using the fact that measurable sets form a sigma algebra, it has been shown that (a,b] is measurable. By taking the union of the sets (a,b-1/n], we can conclude that (a,b) is measurable.
Fermat1
187
I am trying to show that an open set in [0,1] is measurable, given that [0,x] is measurable set for each x in [0,1]. So I need to show (a,b) is measurable. Using the fact that measurable sets form a sigma algebra, I have managed to show that (a,b] is measurable. So (a,b+t] is measurable for any t>0. letting t ->0, can I then conclude that (a,b) is measurable? It seems a bit easy that I can just relax closed intervals to open intervals in this way.
You are given, then, that (0, a) and (0, b) are measurable and you can write (a,b)= (0, b)\ (0, a).
Not quite, there are two things wrong here. First, in a sigma-algebra, you must use countable unions and intersections. So instead of $t$ you should have $1/n$. Then you can take the intersection of the sets $\bigl(a,b+\frac1n\bigr]$. That leads us to the second thing that is wrong, namely the fact that \(\displaystyle \bigcap_n \bigl(a,b+\tfrac1n\bigr] = (a,b]\): you still have an interval that is closed at the upper end!
What you need to do is to take the union of the sets $\bigl(a,b-\frac1n\bigr]$, which is $(a,b)$.
FAQ: Measurability of Open Sets in [0,1]
What is the "measurability" of open sets in [0,1]?
The "measurability" of open sets in [0,1] refers to whether or not these sets can be measured or assigned a numerical value in terms of their size or volume. In mathematical terms, it is a measure of the extent to which these sets can be quantified.
How is the measurability of open sets determined?
The measurability of open sets is determined by whether or not they satisfy certain mathematical criteria. In particular, a set is considered measurable if it can be approximated by other sets with known measures.
Why is the measurability of open sets important?
The measurability of open sets is important in mathematics and science because it allows us to quantify and analyze these sets, which can help us understand and make predictions about various phenomena. It is also a fundamental concept in measure theory, which has numerous applications in fields such as physics, economics, and engineering.
Are all open sets in [0,1] measurable?
No, not all open sets in [0,1] are measurable. In fact, the set of non-measurable open sets in [0,1] is large and infinite. This is because, in general, it is difficult to define a measure for these sets in a consistent and meaningful way.
How does the measurability of open sets in [0,1] relate to other mathematical concepts?
The measurability of open sets in [0,1] is closely related to other mathematical concepts such as Lebesgue measure, which is a way of assigning a numerical value to a set in [0,1] based on its size or volume. It is also related to the concepts of measure spaces and sigma-algebras, which are used to define and study measurable sets in a more general setting.
