Measurable quantites vs Base units
In summary, the three units that are special are length, time, and amount. Everything else is measured in terms of these three. There is something special about these three things and they are not just amounts.
elegysix
406
So here's the familiar SI base units from NIST
length
mass
time
electric current
thermodynamic temperature
amount (mole)
luminous intensity
Something has been bugging me about this.
For whatever reason I am thinking all quantities are calculated by just three on the list -
Lengths, times, and amounts.
There's something special about these three things. Are these the only units we can really measure? (or observe?)
What I'm getting at is that you can't really measure something like mass. It's calculated from displacement of a spring or whatever method you prefer. The same goes for current, it's calculated from a count (amount) and time. temperature is calculated by the displacement of mercury, but do you see what I mean? the actual measuring (or observing) part of everything comes down to lengths, times, and amounts.
Does anyone follow me? Does that seem strange? What are your thoughts on this?
(I might be abusing the word measure here, maybe observe is a better choice?)
Please explain to me what you mean by amount?
You also need a definition of either charge or current.
And time would be nice as well - otherwise you are stuck in a static world!
And you will find that every measurement is made in terms of other "things" - there is always an intermediary. Thus the requirement for standards. The standards rely upon physical laws which relate the quantities.
well yeah like you cannot explain current in amounts and time only
for eg.
1-CURRENT = θ/T
θ IS YOUR SPOKEN AMOUNT
T IS YOUR TIME
2-BUT QUESTION WILL COME WHAT AMOUNT
AND NOW IF YOU USE SOME THING LIKE 10 COULOMB CHARGE
3-MY NEXT INTERROGATION IS WHAT IS COULOMB
THEN PROBABLY (by definition) YOU MUST SAY
1C IS 'amount' of charge flowing when 1 ampere current flows for one second
4-I AGAIN ASK WHAT IS CURRENT BETTER USE AMPERE:-p
(MY COMMENT IS WEIRD SORRY)
Can't current be 'measured' by the number of charge carriers which pass a point in a specific time?
That's just an amount, and a time.
Well, the current depends on "how much charge" each carrier is carrying as well as the number of carriers per unit time.
What I don't understand is, why are time and length different from "amounts"?
They seem to me to be an "amount" as much as everything else is
That reduces your question to "why is everything measured in amounts" which is just because of the mathematical ground that science rests on.Maybe I'm overlooking something here, but what's unique about time and length that they can't be considered "merely amounts"?
I don't know. I guess length is really a matter of two positions. I see what you mean when you say something is some amount of inches. Maybe position is a better term to use than length for this.
Time follows similarly, however I can't think of a word for a similar 'position in time'
So that leaves us with position and 'position in time' are not amounts.
Position and date/time is relative to a coordinate system. Coordinate systems are arbitrary. What is not arbitrary is "distance" and "duration".
This is true - there are two very special things about position in space and position in time, but it is not (as you assert in you first post) that they are the only things we can measure directly - in fact it is the opposite.
They are the only things that CANNOT be measured exactly, and they are the only things whose measurement is dependent on the observer. They are therefore no good as bases for a system of units, and that is why we use the difference between two points in space and in time as our bases. The other quantities measured by SI units however can (in principle) be measured exactly and are identical for all observers and are therefore defined absolutely.
I would say time is an amount of a cycle.
For example, 1 second is a certain amount of atmoic cycles (I don't know exactly how it's measured)
It's like UltrafastPED said, every "thing" is described in terms of another "thing" (as evidenced by the very notion of units)
Even length is measured in terms of length in Euclid. You choose two points, this distance is your unit of distance; everything else is scaled up or down from this arbitrary unit.
Actually, you can define charge purely in terms of kinematical quantities. This is the approach taken by Gaussian units. One statcoulomb has dimensions of ##M^{1/2}L^{3/2}T^{-1}##
To the OP, the required fundamental units is not actually entirely constrained by physics. It is mostly a matter of convention which is determined by the system of units. You should compare SI, Gaussian units, and geometrized units for some examples.
This is quite the observation. I should've realized this sooner.
I agree we can't determine some 'absolute' position or position in time, and so we use the differences between two positions and two positions in time.
However, it seems to me that these two things which we can't measure exactly, are the only two observable properties (for lack of a better word) of things - and their differences being the only truly measurable things (observed and quantified).
I think all the other "base units" are calculated (not measured) from combinations of differences of positions and times (measured) of things related to various objects, while the actual "base unit" chosen depends on what the thing and object is (and to an equal degree the specific combination of lengths and times).
(I am thinking now that an amount can simply be reduced to a group of positions)
Let's call this group of observable and quantifiable properties (length and time), 'basic units'.
So mass for example, isn't a basic unit, because it isn't directly observable. The only way to determine mass is by measuring the basic units (in some specific way) and fitting an equation of motion to those measurements.
Am I making any sense?
It actually depends on the system of units. In principle you can reduce everything to length. See my comments above in post 13, and compare SI, Gaussian, and geometrized units.
ok i provide you a large charge carrier carrying charge of 1010101010 :-p electrons
now define current vs one 'charge carrier' like single electron
Your 'amounts are same' but current...
I don't really think this is the case, because what is done with the measurements (lengths and times) or how they are quantified, is beside the point. However I did find geometrized units to be particularly odd. But that is a different discussion, so I made a new thread for my questions on them.
However, I would like to know the logic behind reducing everything to length
I don't see how you could possibly think it is beside the point. You have looked at the SI base units and correctly concluded that they are not the only possible set of base units. I have pointed out other systems with different sets of base units, thereby confirming your point.
In what way is providing a few concrete examples of your point besides the point?
Yes it can, and it is likely that this is how the Ampere will be re-defined in a few years. The realization will then by some sort of electron pump that send electrons one at a time and the current will be I=e*f where e is the electron charge and f the pump frequency. e would then be defined to have an exact value. These devices already exist, but at the moment they are not quite accurate enough (they need to improve by about a factor of 5).
However, this would not in any way change the fact that the Ampere is a base unit in the SI; only the definition(and realization) will change.
Related to Measurable quantites vs Base units
1. What are measurable quantities and base units?
Measurable quantities are attributes or characteristics of a physical object or phenomenon that can be measured or quantified using numerical values. Base units, on the other hand, are the fundamental units of measurement that all other units are derived from.
2. How are measurable quantities and base units related?
Measurable quantities are typically expressed in terms of base units. For example, length can be measured in base unit meters, and time can be measured in base unit seconds. Other units, such as kilometers for length or minutes for time, are derived from these base units.
3. Why are base units important in scientific measurements?
Base units provide a standard and consistent way to measure and compare different physical quantities. This allows for accurate and precise measurements, as well as easy conversion between different units of measurement.
4. Are there different systems of base units?
Yes, there are different systems of base units, such as the International System of Units (SI) and the Imperial System. The SI system is the most commonly used and is based on seven base units: meter, kilogram, second, ampere, kelvin, mole, and candela.
5. How do we determine the appropriate units for a given measurable quantity?
The appropriate units for a measurable quantity depend on the nature of the quantity being measured. For example, length is typically measured in meters, while mass is measured in kilograms. It is important to choose the base unit that is most relevant and appropriate for the quantity being measured.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • Art, Music, History, and Linguistics
