I Measurement of a qubit in the computational basis - Phase estimation
Peter_Newman
Hello,
I have a question about the measurement of a qubit in the computational basis. I would like to first state what I know so far and then ask my actual question at the end.What I know:
Let's say we have a qubit in the general state of ##|\psi\rangle = \alpha|0\rangle + \beta|1\rangle##. Now we can define the following measurement operators depending on whether we want to measure the qubit in state ##|0\rangle## or ##|1\rangle##. Let's say I am interested in the state ##|0\rangle##.
The corresponding operator would then be defined as follows ##M_0 = |0\rangle\langle 0|##. The probability of obtaining a measurement outcome ##0## is then defined by:
$$p(0)=\langle \psi|M_0^\dagger M_0|\psi\rangle = \langle\psi|M_0|\psi\rangle = |\alpha|^2$$.My Question:
I read the following in the Wikipedia article on Quantum Phase Estimation (Wiki, section measurement). We have now given there the following quantum state:
$$\frac{1}{2^n}\sum_{x=0}^{2^n-1}\sum_{k=0}^{2^n-1} e^{-\frac{2\pi i k}{2^n}}e^{2\pi i \delta k}|x\rangle|\psi\rangle$$
Now it is said that a measurement in the computational basis on the first register yields the result ##|a\rangle## with probability;
$$Pr(a) = \left|\left\langle a\left| \frac{1}{2^n}\sum_{x=0}^{2^n-1}\sum_{k=0}^{2^n-1} e^{-\frac{2\pi i k}{2^n}}e^{2\pi i \delta k}\right|x\right\rangle\right|^2 = \frac{1}{2^{2n}}\left| \sum_{k=0}^{2^n-1} e^{2\pi i \delta k} \right|^2$$
I am interested in the last equation here (##Pr(a) = ...##), how do you arrive at it? With what I know so far, I can't really derive the last equation, so I would be interested in knowing how the derivation is. Also the simplification does not open up to me. Maybe someone here can demystify it.
It seems to me like there is a term (x-a) missing in the exponential function. Might that be the case?
Likes Peter_Newman
Yes that is unfortunately correct!
I would like to improve my first post regarding this error. Unfortunately, I can no longer edit this one...
Correct it is:
$$\frac{1}{2^n}\sum_{x=0}^{2^n-1}\sum_{k=0}^{2^n-1} e^{-\frac{2\pi i k}{2^n}(x-a)}e^{2\pi i \delta k}|x\rangle|\psi\rangle$$
$$Pr(a) = \left|\left\langle a\left| \frac{1}{2^n}\sum_{x=0}^{2^n-1}\sum_{k=0}^{2^n-1} e^{-\frac{2\pi i k}{2^n}(x-a)}e^{2\pi i \delta k}\right|x\right\rangle\right|^2 = \frac{1}{2^{2n}}\left| \sum_{k=0}^{2^n-1} e^{2\pi i \delta k} \right|^2$$
Based on this, I would now assert the following as to why one come up with ##\frac{1}{2^{2n}}\left| \sum_{k=0}^{2^n-1} e^{2\pi i \delta k} \right|^2##.
So the scalar product of ##\langle a|x\rangle## is only 1 if ##a = x##, if this is the case, everything reduces to ##\frac{1}{2^{2n}}\left| \sum_{k=0}^{2^n-1} e^{2\pi i \delta k} \right|^2##, where we put out the constant ##\left|\frac{1}{2^n}\right|^2 = \frac{1}{2^{2n}}##and note that one of the exp terms is 1 since ##e^0## iff ##a = x##. Right? For all other ##a \neq x##, the scalar product is ##0##. Therefore, ## \frac{1}{2^{2n}}\left| \sum_{k=0}^{2^n-1} e^{2\pi i \delta k} \right|^2## then follows.
That looks reasonable to me.
Likes Peter_Newman
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
