Measurement of heat as an interval measurement or a ratio measurement
In summary, the measurement of heat can be classified as either an interval measurement or a ratio measurement. Interval measurements, such as Celsius or Fahrenheit, have equal intervals between values but lack a true zero point, meaning they cannot express true ratios. In contrast, ratio measurements, like Kelvin, possess a true zero, allowing for meaningful comparisons of magnitude and the ability to express ratios. Understanding these distinctions is crucial for accurate scientific analysis and interpretation of thermal phenomena.
jonohashmo543
TL;DR Summary
determining if a measurement of heat is absolute or arbitrary.
Hello!
I am new to this forum and I'm not even sure if this is the right place to ask but here goes:
I am studying Research Methods. I got to the part where the teacher is teaching us about levels of measurement. They said that there are a few levels but the two that are significant to my question are Interval and Ratio.
Interval: As my teacher explained, shoe size measurement is an example of an interval measurement. If someone has a shoe size of 0, we do not think that their feet have 0 length. Similarly, if someone has a shoe size of 4, we do not think that someone with a shoe size of 8 has feet that are literally two times the length of the person with size 4 shoes.
Ratio: A ratio measurement is like the metric system. We know that 0 literally means 0, and that 8cm is literally twice as long as 4cm.
Then the teacher gave Temperature as an example for Interval measurement. That confused me greatly. If we look at Fahrenheit for example, does 0 F have any significance? Is it absolute? Similarly, can we say that 60 F is literally "twice as hot" as 30 F? What if the same questions were asked in Celsius? Or Kelvin?
Basically, I'm wondering if there is an agreed upon absolute measurement for heat, (like metric system in shoe size example) and scales like Fahrenheit Celsius and Kelvin are just plopped on top of that absolute measurement with increments of their own?
Sorry if this is irrelevant to this forum, I just don't really know where to ask this question.
Thanks!
Jonathan
Science news on Phys.org
There are temperature scales where zero is "really zero." These are called "absolute temperature scales." The Rankine and Kelvin scales are "absolute."
I'm sure the wiki page on the Fahrenheit scale explains the significance of zero degrees F.
If you convert these values (60 and 30F) to Celsius (or Kelvin) you will see that "twice as hot" is not right. But if you convert to two different absolute scales (say, R and K) then the ratio should be the same. That's the beauty of absolute scales.
When I went to school (lo those many years ago) we were taught that "heat" is a transfer of thermal energy. In the same way that "impulse" is a transfer of momentum and "work" is a transfer of mechanical energy.
For this notion of heat there are definitely absolute units. Such as the BTU, the Calorie or the Joule. The zero on the each scale indicates that no thermal energy is transferred.
However, you may be thinking of "heat" as a measure of how much thermal energy is present in a body. For typical everyday conditions, the amount of thermal energy in a body goes to zero as temperature goes toward absolute zero. For an ideal gas, this is exactly true. For real substances it is only approximately true.
For every day conditions, "temperature" closely matches kinetic energy per particle per degree of freedom. See this link. Following this pattern, we would expect zero energy at zero Kelvin. But when things get cold, it is useful to shift to a different and more general definition of temperature in terms of the ratio of the incremental change in entropy divided by the incremental change in thermal energy:$$\frac{1}{T}=\frac{dS}{dE}$$[There are some caveats].
This definition eliminates the requirement that energy be zero at absolute zero. It also makes the actual value of thermal energy irrelevant. All that matters is how it changes relative to entropy. This definition also makes absolute zero unachievable and negative temperatures achievable. However, because the definition is for inverse temperature, the scale is a bit strange. All negative temperatures are "hotter" than all positive temperatures.
Here is a link to a Wiki article about thermodynamic temperature that may help you sleep tonight.
Likes Bystander
I'm sure the wiki page on the Fahrenheit scale explains the significance of zero degrees F.If you convert these values (60 and 30F) to Celsius (or Kelvin) you will see that "twice as hot" is not right. But if you convert to two different absolute scales (say, R and K) then the ratio should be the same. That's the beauty of absolute scales.
Thank you so much for your reply!
When converting 60 and 30 F to R or K the values are still not twice as much... so the absolute scales also shift in different ways?
Thank you so much for your beautifully detailed reply!
Unfortunately, as someone who did not study physics at a high level, this is beyond my understanding. But from what I do understand, it seems like all scales of "temperature" are not ratio scales, since absolute zero is impossible to achieve in "temperature" (even though it sounds like that in "heat" it is possible).
Is that true?
In my view, absolute temperature (e.g. Kelvin or Rankine) is a ratio scale. We can see this in various formulae from thermodynamics and chemistry.
For instance, the ideal gas law (##pV=nRT##), Charle's law (##V=kT##) or Carnot efficiency (##n_\text{max} = \frac{T_L}{T_H}##)
Double the temperature and you double the pressure. That sounds like a ratio situation to me.
Do not get too hung up on terminology. If you understand how things work, the names under which you classify them are of minor importance. Now if we could only convince your teachers of that...
Likes jonohashmo543
Here's 60 and 30F in other scales. The bottom row is the ratio of "60" to "30." For F and C scales, it is just nonsense, because the scales are not absolute. Looking at the R and K scales, even though the particular values differ, the ratio is the same. A temperature of 60F is in a sense, "1.06 times as hot" as 30F.
\begin {array}{|c|c|c|c|}
\hline F&C&R&K \\
\hline 60&15.56&520&289 \\
\hline 30&-1.11&490&272 \\
\hline 2.00&-14.02&1.06&1.06 \\
\hline
\end {array}
Likes Bystander, jonohashmo543 and jbriggs444
Hahahahaha! If only indeed. Thanks so much for your help in this:)
\hline F&C&R&K \\
\hline
\end {array}
This is so interesting!!! Thanks so much for this! I completely understand now:)
Likes gmax137
jonohashmo543 said:
TL;DR Summary: determining if a measurement of heat is absolute or arbitrary.
No. It's highly relevant to bear this in mind whenever trying to community a value to someone. The only quantities that are rock solid are integers. "Seven footballs" is hard to mis-interpret but, even integer values may not be bomb proof. "Three potatoes" in a recipe book won't tell you how much actual potato mass is needed.
This is all about quantisation; if there is a continuum of possible lengths and only so many 'bins' to put them in, we have to use quantisation. This applies whenever data is 'digitised'.
If we want a meaningful relationship between the bins which we choose and scientific equations which assume a continuous range of possible values then the bin values (intervals) need to be chosen more carefully than is done in the case of shoes. For shoes, the bins are chosen to fit the requirements of the market and the convenience of the manufacturing and supply chain. If the quantisation (step sizes) is arbitrary then we can't apply simple algebraic formulae (e.g. SUVAT equations). The quantisation of shoe sizes is non-linear.
A minefield, here. Commonly stated temperatures are quantised and with an Origin (the zero point) that is arbitrary. But we certainly need to use intervals less than 1C (even on our central heating control)
People try to talk in terms of "twice as warm as it was yesterday" which is total nonsense and very misleading. The Centigrade scale has one serious advantage in which we can recognise Zero C and 100C by what we can actually see happens to water.
FAQ: Measurement of heat as an interval measurement or a ratio measurement
What is the difference between interval and ratio measurements in the context of heat?
Interval measurements have equal intervals between values but no true zero point, meaning you can't make meaningful statements about how many times hotter one object is compared to another. Temperature in Celsius or Fahrenheit is an example of interval measurement. Ratio measurements, on the other hand, have a true zero point, allowing for statements about how many times one value is compared to another. Temperature in Kelvin is an example of ratio measurement.
Why is temperature in Kelvin considered a ratio measurement?
Temperature in Kelvin is considered a ratio measurement because it has a true zero point (absolute zero, 0 K), where molecular motion theoretically stops. This allows for meaningful comparisons of magnitudes. For instance, 200 K is twice as hot as 100 K, which is not possible with Celsius or Fahrenheit scales.
Can temperature in Celsius or Fahrenheit be considered a ratio measurement?
No, temperature in Celsius or Fahrenheit cannot be considered a ratio measurement because they do not have a true zero point. Zero degrees Celsius or Fahrenheit does not signify the absence of thermal energy, making it impossible to make meaningful multiplicative comparisons.
How do interval and ratio measurements affect scientific calculations involving heat?
Interval measurements, like Celsius or Fahrenheit, are useful for measuring temperature differences but not for calculations requiring a true zero point, such as those involving ratios or proportions. Ratio measurements, like Kelvin, are essential for thermodynamic calculations because they allow for meaningful comparisons and proportional reasoning.
What are some practical applications of using ratio measurements for heat?
Practical applications of using ratio measurements for heat include thermodynamic calculations, such as those in the fields of physics and engineering. For example, in calculating the efficiency of heat engines, the temperatures must be in Kelvin to accurately determine ratios and proportions. This ensures precise and meaningful results in scientific and industrial processes.
