Measurement of the Speed of light
In summary: If the photon is not a strictly massless particle, it would not move at the exact speed of light, c in vacuum.This is not necessarily true. If the photon has a small mass, then it might not move at the speed of light in a vacuum, assuming the vacuum is perfect. However, if the photon has a very small mass, then it might not move at all.
sqljunkey
181
Hi,
What is people measuring when they measure the speed of light (c) actually? the photons or the waves? or some kind of manifestation of light?
I ask because I was reading about photons and that they "might" have a very small mass and therefore are not traveling at c. If photons have a mass, and are traveling slower than c what exactly is being measured when they measure the speed of light?
Thanks
Science news on Phys.org
They're measuring light. The different things you mention are not different possible things they could be measuring; they're just different ways of describing light in ordinary language.
Please give a specific reference.
This is logically possible in the sense that you can write down a self-consistent theory of light in which photons have a nonzero mass; however, all experiments have shown that photons have zero mass.
Likes anorlunda
If the photon is not a strictly massless particle, it would not move at the exact speed of light, c in vacuum. Its speed would be lower and depend on its frequency. Relativity would be unaffected by this; the so-called speed of light, c, would then not be the actual speed at which light moves, but a constant of nature which is the upper bound on speed that any object could theoretically attain in space-time.[29] https://en.wikipedia.org/wiki/Photon#Experimental_checks_on_photon_mass
and also
But some theories allow photons to have a small rest mass and one consequence of that would be that photons could then decay into lighter elementary particles. http://physicsworld.com/cws/article/news/2013/jul/24/what-is-the-lifetime-of-a-photon
This is more correctly phrased as: if the photon were not a strictly massless particle, then the speed of light in vacuum would not be precisely equal to the invariant speed--the speed which is the same in all reference frames. The speed of light in vacuum would instead be variable, always lower than the invariant speed, but it would be possible in principle (though not necessarily likely in practice) to find a reference frame in which a photon was at rest.
In other words, our usual terminology, which refers to the invariant speed as "the speed of light", assumes that photons are massless; if that assumption were to turn out to be wrong, the correct response would be to change our usual terminology, so that it would draw a clear distinction between the speed of light and the invariant speed.
If there were any.
They are measuring the speed of a beam of light. That beam can be modeled as either a stream of photons or a wave.
That depends on your definition of ##c##. You either define it as the fastest possible speed or your define it as the speed of light. Right now we don't need to make that distinction because all observations and experimental results indicate that those two speeds are the same.
Related to Measurement of the Speed of light
1. What is the speed of light?
The speed of light is a physical constant that represents the speed at which light travels in a vacuum. It is approximately 299,792,458 meters per second, or about 186,282 miles per second.
2. How is the speed of light measured?
The speed of light can be measured using various techniques, such as the Fizeau-Foucault apparatus or the Michelson interferometer. These methods involve measuring the time it takes for light to travel a known distance and then using the equation speed = distance/time to calculate its speed.
3. Why is the speed of light considered a constant?
The speed of light is considered a constant because it is the same for all observers, regardless of their relative motion or the direction of the light source. This is a fundamental principle of Einstein's theory of relativity.
4. Has the speed of light ever been measured accurately?
Yes, the speed of light has been measured with increasing accuracy over the years. The first accurate measurement was done in 1676 by Danish astronomer Ole Rømer, and it has been refined and confirmed by numerous experiments since then.
5. Can the speed of light be exceeded?
According to Einstein's theory of relativity, it is impossible for any object with mass to travel at the speed of light or exceed it. However, some scientists have proposed theories that suggest the existence of particles that can travel faster than light, but these have not yet been confirmed.
  • Optics
