A Measurement uncertainty due to thermal noise
The discussion centers on the behavior of a charged particle in a Penning trap, specifically focusing on its axial motion modeled as a damped harmonic oscillator influenced by thermal noise from a connected RLC circuit. The participant seeks to quantify the uncertainty in the particle's position due to this thermal noise, proposing the use of a Langevin equation to incorporate random and dissipative forces. A suggestion is made to calculate noise power and its effects on the particle's motion, referencing the Rice distribution for understanding fluctuations in a sinusoidal motion under Gaussian noise. The conversation also touches on the Cramer-Rao lower bound, which provides a theoretical limit on the uncertainty of measurements in the presence of noise. Overall, the interaction between thermal noise and the damped oscillatory motion of the particle is a key focus of the discussion.
kelly0303
I have a charged particle in a Penning trap. The particle motion is non-relativistic and the energy is high enough such that we can assume it is not in the quantum regime. For the purpose of the question I am interested only in the axial motion of the particle, so basically this is a classical simple harmonic oscillator. In the ideal case, the equation of motion is simply ##z(t)=z_0cos(\omega_0 t)##, where ##\omega_0## is the resonant axial frequency and ##z_0## is the amplitude given by the initial energy of the particle.
Now assume I connect the trap to a resonant RLC circuit, with resonant frequency ##\omega_0##, at temperature ##T##, such that the motion of the particle is damped with a damping coefficient ##\gamma##. Now the motion can be simply described by a damped harmonic oscillator equation.
However, I am interested in how the thermal noise of the circuit comes into play. I read a bit about noise theory and there is a pretty straight forward formula for the noise spectrum as a function of the frequency. However I am interested in how does the uncertainty in the position at a given time t is affected by the noise.
Of course we can't precisely tell the position anymore, as the thermal noise is random, but I would like to assign an uncertainty to it. Basically, I have ##z(t)## from the damped harmonic oscillator formula and I would like to add to it a ##dz(t)##, which is the uncertainty for a given time and position (as a function of probably ##\gamma## and ##T##). How can I do this? Thank you!
I'd consider to describe this by a Langevin equation, i.e., in addition to the force due to the em. field in the Penning trap you have a friction (dissipative) force and a random force, which you can assume to be described by white noise (diffusion). The friction/drag and the diffusion coefficients are related by the Einstein dissipation-fluctuation relation, ensuring that in the long time limit the particle comes in to thermal equilibrium with the heat bath.
https://en.wikipedia.org/wiki/Langevin_equation
May I suggest a simplistic answer? Assuming a series RLC circuit, the noise power Pn will be 2kTB, where k is Boltzmann's Constant, and the noise current will be sqrt (Pn/R). Bandwidth B = centre frequency/Q. And Q=Xl / R. As this current is entirely carried by the motion of the electron, which is in series with LCR, the RMS velocity of the electron will be fluctuate by vel=I/q. This fluctuation velocity will be added continuosly to any other motion of the electron.
The distribution of a sinusoid in Gaussian noise is the Rice distribution. You can easily look up it up to find the variance or standard deviation. Damped sinusoids are much more complicated, however. Here is a paper that gives the Cramer-Rao lower bound on the variance of the estimated amplitude, frequency and damping constant for a damped sinusoid in Gaussian noise. The CRLB, which is valid at medium to high SNR, is the absolute lowest uncertainty possible. You may achieve this bound or not, depending on your measurement and analysis techniques. (In the radar world, for example, maximum likelihood estimation (MLE) achieves the CRLB for range estimation but does not when used to estimate angle of arrival.)
https://www.ese.wustl.edu/~nehorai/paper/papersadd/ieeetsp91-3.pdf
Likes berkeman and vanhees71
It appears to me that the noise power which is jiggling the electron arises from the warm resistance in the tuned circuit. If the tuned circuit also has damped oscillation that is separate and unrelated. The current and voltage from the thermal noise and the damped oscillation just add but do not interact.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
