Measurements Calculation Problem
The discussion revolves around a calculation error in determining how many candies can fill a container. The original poster consistently arrived at an answer that was a factor of ten off from the solutions manual. They detailed their calculations, including the surface area and volume of the candies, but struggled to identify where they went wrong. Ultimately, they discovered that they had incorrectly calculated the surface area of the candies, leading to the repeated mistake. This realization highlights the importance of careful measurement and verification in mathematical problems.
Ascendant0
A vertical container with base area measuring 14.0 cm by
17.0 cm is being filled with identical pieces of candy, each with a
volume of 50.0 mm3 and a mass of 0.0200 g. Assume that the volume
of the empty spaces between the candies is negligible. If the height
of the candies in the container increases at the rate of 0.250 cm/s, at
what rate (kilograms per minute) does the mass of the candies in
the container increase?
N/A (It's the "Measurements" chapter, that's focusing on us familiarizing ourselves with implementing measurements into mathematical problems)
I have done this problem three times now, and keep coming up with an answer that is a factor of 10 off from the answer in the solutions manual. The way I'm doing it is MUCH different than how they did it, so I can't use their method to see where I'm going wrong. I want to find out what I'm doing wrong in my method. I can't figure out where I'm converting wrong and it's driving me crazy. Here's what I do:
The base of the container = 14cm x 17cm = 238cm^2
Candy (converted to cm for later) = 5x10^-2cm^3 (volume) ; 1.357cm^2 (area of one side); 0.368cm (length of one side)
Candy (mass converted to kg for later) = 2x10^(-5)kg
To find out how many candies it would take to fill the surface area of the base of the container (238cm^2), I take the surface area of each candy and divide it into it:
238cm^2/1.357cm^2 = 175.387pcs (from my thought process, this is how many pieces it would take to have a layer of candies completely cover the base of the container, so for every 175.387 pieces, the height of the candies would increase by one additional stack/height (length) of candy, which is 0.368cm from my calculation)
Based on that calculation, and that the length of a side of each candy is 0.368cm, that means for every 175.387 pieces of candy, the height in the container would increase by 0.368cm, right? So with that in mind, I then calculate how many pieces it would take to increase the height by 0.25cm/sec:
175.387pcs/0.368cm = (x)pcs/0.25cm +> x = 119.148pcs per second would fill the container at a rate of 0.25cm per second, right?
So then, I take that value and convert it into how much that would cause the weight to increase per minute:
119.148pcs/1sec * (60sec/1min) * (2x10^-5kg) = 0.143kg/min (my answer)
So, my answer I got is at an increase of 0.25cm/sec, the weight would be increasing by 0.143kg/min. However, their answer in the solutions manual is 1.43kg/min. So, I would assume that somehow, I converted my measurements wrong, which shifted my answer one decimal place off. But again, I've done this three times now, and I keep getting the same exact answer every single time.
I know there is other ways to calculate it, as theirs in the solutions manual, but I'd really like to know where I'm going wrong here with this method?
Omg, nevermind, I found it. I messed up on the surface area of the candies. One side should be 0.1357cm^2, NOT 1.357^2. How I made that same exact mistake three consecutive times is beyond me. Sorry for wasting anyone's time, I can't believe I messed up math as simple as that...
Likes docnet and BvU
No better way to learn and make progress than finding your own mistakes and fixing them :smile:
it happens to the best of us.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
