Measuring a paper clip with precision
In summary, Precision is how close the measured values are to each other and procedure two would provide the most precise measurement.
dirtcrazy
You are asked to find the weight of a paper clip as accurately as possible and given ten paper clips and a scale that has a precision of 0.1 g. (A paper clip weighs about 1 g.) Which of the following proceedures would give you the most precise measurement the weight of a paper clip?
  1. Weigh each paper clip individually, average the values and calculate the standard error.
  2. Place all ten paper clips on the scale at once, then divide the value and the precision of the scale by ten.
Explain your reasoning.
N/A
Precision is how close the measured values are to each other. With this being said procedure two would provide the most precise measurement. Procedure one would be much more accurate because it is measuring each paper clip individually to find how close the measurement of the weight is to the actual weight (1.0g). In procedure two all ten paper clips are measured at once meaning the value of the weight divided by 10 would be the average.I am not sure if my reasoning is correct. Any thoughts?
This is, I think, an ill-worded problem. It says "find the weight of a paper clip". Why measure more than one if you are just looking for the weight of one, and why even ask for the error when you know that the scale has a specified error? If in fact the problem wants the average weight, then doing all 10 at once is much better since you still only have an absolute error the same as if you measured just one.
First, I second phinds' objection that the question ought to be asking for how best to detemine the average weight of the ten paperclips.
In your attempt at solution, I'm not sure which you are saying gives the better estimate of the average weight. You seem to be having a bet each way. And I see nothing there that constitutes a reason - you merely assert that one or other is better.
Are you familiar with concepts such as independent random variables, identical distributions, variance, expected error and sample sizes?
Related to Measuring a paper clip with precision
1. How do you measure a paper clip with precision?
To measure a paper clip with precision, you will need a ruler or a caliper with millimeter measurements. Place the paper clip on a flat surface and use the ruler or caliper to measure the length of the paper clip from end to end. Make sure to measure from the innermost points of the paper clip for the most accurate measurement.
2. Why is it important to measure a paper clip with precision?
Measuring a paper clip with precision is important for several reasons. It allows for consistency and accuracy in measurements, which is crucial in scientific experiments and research. It also ensures that the paper clip is being used correctly for its intended purpose, such as holding a specific amount of paper or fitting into a specific space.
3. What is the most accurate tool for measuring a paper clip?
The most accurate tool for measuring a paper clip is a caliper. A caliper is a specialized measuring tool that uses two jaws to measure the distance between two points. It can measure the length of a paper clip with precision down to the millimeter, making it the best tool for precise measurements.
4. Can you measure a paper clip with a regular ruler?
Yes, you can measure a paper clip with a regular ruler. However, using a ruler may not provide the same level of precision as a caliper. A ruler typically measures in centimeters or inches, which are larger units than millimeters. This may result in a less accurate measurement of the paper clip's length.
5. What are some potential sources of error when measuring a paper clip with precision?
Some potential sources of error when measuring a paper clip with precision include human error, such as not aligning the ruler or caliper correctly or not reading the measurement accurately. The paper clip itself may also have slight variations in length, which can affect the measurement. It is important to take multiple measurements and calculate an average for the most accurate result.
