- #36
Hurkyl
Staff Emeritus
- 28
rbj said:BTW, i didn't say vectors with real components aren't real, and i don't think you can successful use that as evidence of an inconsistancy - vectors are different than complex numbers
Okay, then can explain to me why your argument that the complexes are not "real" fails to apply just as well to vectors?
(This question, incidentally, is the one I'm most interested in hearing answered)
Phase is circular. The reals are linear. Circles are not lines. 0 and 360 are different real numbers, but 0° and 360° are identical phase differences.so how is phase difference not real?
What "real" meaning does the unit have? I can't think of a "physical quantity" where +1 has an absolute meaning: the + is simply denoting an orientation with respect to a chosen convention, and the 1 is simply denoting a scale with respect to a chosen unit.Real numbers are qualitatively different. the unit in the real number line (i.e. the number "1") is the multiplicative identity and is qualitatively different than its negative "-1". but the unit in the imaginary line, the imaginary unit that we conceive and label i is qualitatively no different than its negative -i. both have equal claim to square to be -1. if every textbook and math/science/technical paper in the world was rewritten and -i was substituted in for i (which would also have the effect of replacing every occurace of -i with +i), all facts and theorems would remain equally true. the same cannot be said for +1 and -1. they are not
Multiplication does not have an absolute physical meaning: every physical law involving a multiplication also includes a physical constant that modifies the equation so that the scale and orientation turn out correct.
If we change the units on certain measurements, the physical constants adjust to compensate.
If we change our sign convention, the physical constants adjust to compensate.
We can even change quantities from purely real to purely imaginary, and the physical constants adjust to compensate.
(Algebraically, all three of these amount to exactly the same operation)
e.g. I could select three oriented lengths, one along the up-down axis, one along the East-West axis, and one along the North-South axis. I could then declare that the first one is +1, the second is -3, and the third is 3+2i, and all of physics still works, all physical laws retain their form: the physical constants simply take on values with respect to these new units.
(In summary... of course you can swap -1 and +1! I can also replace +1 with +2 and -1 with -2. I can even replace +1 with +i and -1 with -i, if I choose. It's just that these symmetries are a little bit more involved than that of swapping +i and -i at every single occurence)
