Measuring momentum and position in particle colliders
In summary: So the wave aspect disappears somewhere in the middle, and I am trying to figure out how that happens and why it doesn't happen in a particle collider.In summary, when observing pictures of colliding particles in particle colliders, we see distinct paths marked out by the particles, which can be explained by making multiple observations that collapse the wave function. The uncertainty principle is not violated for these particles, as position is not accurately measured. The concept of wave-particle duality has been abandoned in modern quantum mechanics, and the Mott problem was solved without the use of quantum field theory. The electron's behavior is consistent in both a television tube and
Sophrosyne
128
When we look at those pictures of colliding particles in particle colliders, we see a large collection of curves and lines radiating out from the point of collision, representing the new particles which have been created.
So two questions about this:
1) Why are these acting like particles in the detector, and not waves? They look like very distinct paths marked out by these particles. In other words, why does the wave function for these particles, no matter how small their mass, even as small as neutrinos, stay collapsed as distinct particles during the detection process?
2) It seems these lines are tracing both the velocities and positions of these resultant particles at any given point in time. But this would seem to violate the Heisenberg Uncertainty Principle regarding position and momentum, doesn't it?
Because that's what the detector is measuring--it's measuring the particle aspects of these objects, not wave aspects. (A more detailed answer can't really be given at the "B" level.)
Distinct in a macroscopic sense, yes. But these particles are not macroscopic; there's plenty of room for position uncertainty in the observed tracks without violating the Heisenberg uncertainty principle.
Collapse is an interpretation, which is not needed to analyze these experiments. The basic math of QM plus the properties of the detector are enough to explain why distinct particle-like tracks are observed.
Note also that neutrinos don't appear directly as tracks in the detectors; only their decay products do.
No, they're not. You don't seem to appreciate how tiny these particles are, and how narrow a track can be in a macroscopic sense and still satisfy the Heisenberg uncertainty principle. I suggest trying to run some numbers.
Likes vanhees71
Each observation collapses the wave function. In order to get an observed trajectory or path, one must make multiple observations - one observation for each point in the path. Each observation collapses the wave function.
These path do not violate any of the uncertainty principles of quantum mechanics. Roughly speaking, position is not very accurately measured in these paths.
You might want to try googling for "Mott problem".
Doesn't violate it for baseballs, right? Why not?
Because baseballs are supposedly not quantum-sized subatomic particles, whereas things like electrons apparently are. Why would an electron act like a wave when it's around an atomic nucleus, but not when it's in a particle collider?
The Mott problem, mentioned above, seems interesting. It seems this was initially a question even for the early pioneers of quantum mechanics, like Heisenberg. I am thinking the answer lies somewhere in the complex equations of quantum field theory, which were developed later. I guess I'm going to have to study those a little more for this to make sense on a more rigorous mathematical basis.
This makes some sense. Thank you.
OK, let's take a step back. Why do electrons have a well-defined trajectory in your (old-style) television tube?
That's not a very good description of the situation; the "wave-particle duality" it's based on was abandoned decades ago and you you won't find it any serious modern textbook. In the modern (meaning after 1930 or thereabouts) formulation of quantum mechanics, the electron follows the exact same quantum mechanical laws in both situations, and in neither does it behave "like a wave" or "like a particle". It behaves like an electron.
The Mott problem was indeed a problem in the early days of quantum mechanics. It's called the "Mott problem" because Mott solved it, and no quantum field theory is required.
To be honest, now I am not sure. But I am thinking of something like what happens in a camera as the light gets focused on the film. As the light is traveling from the lens to the fim, they are superposed probability waves. But when they hit the film, they are acting as discreet photon particles. You seem to be suggesting, from what I understand, that they follow discrete paths that we might theoretically be able to trace from the lens to the film, in the same way that the paths of the electrons are traced in the particle collider.
I guess I am too used to hearing about this idea of wave-particle duality. I have to read up on how this duality is now an obsolete way of thinking about these things. After all, this is how they still present things to the public in popular science articles. Do you have any recommendations for some reading on this?
I see. Looking up "the Mott Problem", this is something I found:
"Mott demonstrated that by considering the interaction in configuration space, where all of the atoms of the cloud chamber play a role, it is overwhelmingly probable that all of the condensed droplets in the cloud chamber will lie close to the same straight line. What is uncertain is which straight line the wave packet will reduce to; the probability distribution of straight tracks is spherically symmetric."
https://en.m.wikipedia.org/wiki/Mott_problem
This is fine. But as each individual atom in the cloud chamber is tracing out the path of the electron, it is revealing both its momentum and position simultaneously to a fairly high degree of certainty. The best answer for this I have seen here yet is that despite this, there is enough uncertainty in both to satisfy Heisenberg's uncertainty Principle.
Be quantitative. How high? Compare that with hbar.
Yeah, I see your point. Thanks.
Related to Measuring momentum and position in particle colliders
1. How do you measure momentum and position in particle colliders?
Particle colliders use various types of detectors to measure the momentum and position of particles. These detectors include silicon detectors, drift chambers, and time projection chambers. The detectors work by tracking the path of particles as they move through the collider, using electric and magnetic fields to bend the particles and determine their momentum and position.
2. What units are used to measure momentum and position in particle colliders?
In particle colliders, momentum is typically measured in units of GeV/c (gigaelectronvolts divided by the speed of light) or MeV/c (megaelectronvolts divided by the speed of light). Position is measured in meters or millimeters, depending on the size of the collider.
3. How precise are the measurements of momentum and position in particle colliders?
The precision of these measurements depends on the type of detector used and the energy of the particles being collided. In general, the precision can range from a few percent to a fraction of a percent for momentum measurements, and from a few millimeters to tens of micrometers for position measurements.
4. What challenges are faced when measuring momentum and position in particle colliders?
One of the main challenges is dealing with the large amount of data produced by the collisions. Particle colliders can produce millions of collisions per second, making it difficult to accurately measure and track individual particles. Another challenge is dealing with the high energies and speeds of the particles, which can cause distortions and errors in the measurements.
5. How are the measurements of momentum and position used in particle physics research?
The measurements of momentum and position in particle colliders are crucial for understanding the fundamental properties of particles and the interactions between them. This data is used to test and validate theories in particle physics, and to search for new particles and phenomena that can help us better understand the universe.
  • Quantum Physics
  • Quantum Physics
