Measuring One-Way Anisotropy of Light Speed
In summary, the experiment proposed by the author appears to have flaws that make it difficult to prove whether one-way light speed differs from the average speed. If current physics are correct, then the receivers should always read zero, regardless of whether or not one-way light speed differs from the average speed.
seb7
66
TL;DR Summary
Proposed method of measuring one-way light speed
I've always thought that light could possibly be transmitted faster in one direction than the other depending on the velocity of its container - despite what the current understanding of physics says! The problem is that its very hard to prove, and to this end I've read through all the different ways one-way light speed has been measured and they all appear to have flaws. So here I'm proposing an experiment which I hoping someone may have the tools to test.
1) central transmitter placed on a large circular board; pulsing with atomic accuracy a beat about 10 times a second.
2) 12 independent receivers placed equally around the board at a distance of about 1 metre from the transmitter. (also require atomic clocks.)
transmission can either be electrical or photons, shouldn't matter.
The receivers constantly attempts to sync by listening to the transmitted pulse, but not using an average, but with the earliest beat over the entire period; then uses this sync to compare with pulses currently being received and displays any differences measured. (between the current and earliest)
The board is then slowly rotated so that they each sync to their earliest time. After a rotation, they should start displaying what differences they are seeing (if one-way speeds do differ).
If current physics are correct, then they should always read zero. If one-way light has any differences in speeds, values greater than zero would appear.
Doesn't work. If you have an anisotropic speed of light then your clocks drift when you move them - time dilation (or the roughly analogous concept, anyway) is no longer isotropic nor necessarily negligible at low speed. If you don't correct your clocks for this drift then you are assuming light speed isotropy; if you do correct them then you are assuming whatever anisotropy you choose to correct for. Either way, you will detect what you assumed.
Isotropy of lightspeed or otherwise is just a choice of coordinate system. There are no detectable physical consequences.
And with the good reply by @Ibix this thread is closed. @seb7 -- we do not allow discussion of personal theories here. You've been with the PF long enough to know that.
Likes Ibix
Related to Measuring One-Way Anisotropy of Light Speed
What is one-way anisotropy of light speed?
The one-way anisotropy of light speed refers to the difference in the speed of light in different directions. This phenomenon has been observed in certain experiments, suggesting that the speed of light may not be constant in all directions.
How is the one-way anisotropy of light speed measured?
One method of measuring the one-way anisotropy of light speed is through the use of Michelson interferometry. This involves splitting a beam of light into two perpendicular paths and measuring the time it takes for the light to travel through each path. Any difference in the times can indicate a difference in the speed of light in those directions.
What factors can affect the measurement of one-way anisotropy of light speed?
There are multiple factors that can affect the measurement of one-way anisotropy of light speed, including the precision of the equipment used, environmental conditions, and the orientation of the experiment relative to Earth's rotation and orbit around the sun.
What are some potential implications of measuring one-way anisotropy of light speed?
If the one-way anisotropy of light speed is confirmed to be a real phenomenon, it could have significant implications for our understanding of the fundamental laws of physics. It may also impact technologies that rely on precise measurements of light speed, such as GPS systems and telecommunications.
What are some current theories or explanations for the observed one-way anisotropy of light speed?
There are several theories that attempt to explain the observed one-way anisotropy of light speed, including the idea of a preferred frame of reference, modifications to the laws of relativity, and the influence of dark matter or dark energy. However, further research and experimentation are needed to fully understand this phenomenon.
