Measuring tension in a nylon loop (springs?)
In summary, you are devising a study looking at the tension required in a surgical prosthesis to produce stability between 2 bones. You want to measure the tension in the prosthesis, but you can't do it with the prosthesis itself because it is too small. You are thinking of using a spring with a known constant attached to the ends of the nylon to measure the tension.
Dunnymel
Warning: I have a minor grasp of physics...
I am devising a study looking at the tension required in a surgical prosthesis (which is essentially a length of nylon with 80LB breaking strain) to produce stability between 2 bones.
The nylon will be placed in a simple loop between 2 structures and I want to tighten the loop until I have produced the desired effect. In practice this means placing the loop, then forming a single knot and applying tension to each end of the loop (ie the first part of tying a shoelace) before securing the loop with additional 'throws' .
Importantly I want to measure the tension that I have produced in the loop.
The loop will be quite small (say 3cm diam) and sitting against tissue which means I will not be able to place a gauge or other device within the loop unless the device is very small.
I was thinking of using a spring with a known constant attached to the ends of the nylon which could be measured once I have the desired physical effect.
Is this the simplest way of measuring the tension in my loop? If so, do I need a spring attached to both ends of the loop as I tension it?
Thanks
Dunnymel
Hi Dunnymel. Welcome to the board. I'm not a strain gauge expert, in fact I've never used one. But the idea is simple enough. Strain of a copper conductor changes the resistance, and the resistance can be measured. Here's an overview:
http://en.wikipedia.org/wiki/Strain_gauge
If you had an extremely thin wire wrapped inside the nylon (string?) you might be able to measure any change in resistance as the nylon stretched. Obviously, the longer the copper, the more accurate you can get, so there's going to be a tradeoff in how complicated you get with the geometry of the wire (ie: how long you can make it) and how accurate you want it. Figure out how accurate you need it, then have someone expert in the field figure out how long it needs to be and how you might be able to mount it.
Thanks, you've just profoundly increased my knowledge on the subject of strain gauges!
..however the nylon I am using is akin to heavy fishing line, about 1.5mm diam, so I can't place anything 'inside'. I would have to use something on the outside surface.
Any other ideas would be great.
Dunnymel.
FAQ: Measuring tension in a nylon loop (springs?)
How do you measure tension in a nylon loop?
To measure tension in a nylon loop, you can use a tension meter or a force gauge. These tools measure the amount of force being applied to the loop and can give you an accurate reading of the tension.
What is the purpose of measuring tension in a nylon loop?
Measuring tension in a nylon loop can help determine the strength and durability of the loop. It can also be useful in determining the appropriate amount of weight or force that can be safely applied to the loop without causing damage.
Can tension be measured in a loop made of other materials?
Yes, tension can be measured in loops made of various materials, including metal, rubber, and plastic. The method of measurement may vary depending on the material, but the concept remains the same.
What factors can affect the tension in a nylon loop?
The tension in a nylon loop can be affected by various factors, including the material and thickness of the loop, the amount of weight or force applied, and the temperature and humidity of the environment. These factors can all impact the overall strength and stability of the loop.
How do you ensure accurate and consistent tension measurements in a nylon loop?
To ensure accurate and consistent tension measurements in a nylon loop, it is important to use the same method and tools each time. It is also crucial to calibrate the measuring instrument regularly and to test the loop under similar conditions each time to eliminate any variables that could affect the results.
