Measuring the critical capillary number
The discussion focuses on measuring the critical capillary number in experiments involving water flooding tests in micro single capillary ducts, specifically displacing oil in oil-wet channels. Key properties of the fluids, such as viscosities, density, interfacial tension, and contact angle, have been measured. The original poster seeks an equation for calculating the critical capillary number or confirmation that it can only be determined through numerical or experimental methods. The conversation confirms that the topic falls under Fluid Mechanics, with suggestions for additional resources on flow rate and viscosity. Overall, the inquiry highlights the complexities of fluid dynamics in microchannel applications.
Talal
Is there a way to measure the critical capillary number?
I am running water flooding tests in micro single capillary ducts. I am displacing oil in my experiment, and my channel should be oil wet.
I was able to measure the properties of both fluids, this includes; Kin and Dyn Viscosities, density, interfacial tension and fluid-fluid contact angle.
Is there an equation to measure the CC number or can the value only be obtained through either numerical or experimental processes?
Help is very much appreciated.
what field do you work in or are studying?
We’re determining where your post will get the most views and possibly responses.
From the looks of it, it seems to be Fluid Mechanics but we’re not sure.
Hello,
Apologies for the late reply. It is Fluid mechanics. I am working on microchannels, and I am a University Researcher.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 17 ·
