Measuring the depth of a lake using a bottle
In summary, to measure the depth of a lake, an empty bottle is lowered to the bottom of the freshwater lake with a weight attached to keep it upright. When recovered, the bottle is filled with 0.58dm^3 of water. Using Boyle's law and the pressure at height h, the depth of the lake can be determined to be 14.3m assuming the bottle is closed at the bottom and taken up. However, if the bottle is open, the air inside will expand and the depth measurement may not be accurate.
lep11
380
To measure the depth of a lake, an empty bottle (V=1dm^3) is lowered to the bottom of the freshwater lake. There is a weight attached to the bottom of the bottle to keep it upright. When the bottle is recovered it is filled with 0,58dm^3 of water. Determine the depth of the lake. Assume constant temperature and standard atmospheric conditions.
Boyle's law says pV=constant
pressure at height h is p(atm)+density of water*g*h
V2=0,42dm3[/B]
p2=(p1V1)/V2=p(atm)+density of water*g*h
I solve for h and i got h=14,3m after substituting numbers in. Am I right?
It is not entirely clear what the procedure for recovering the bottle is. Is it closed at the bottom of the lake such that its contents are fixed to those at that depth? Otherwise the air will just expand again when the bottle is lifted up. This is assuming the opening of the bottle is facing down, if it is facing up the air will simply escape the bottle.
Assuming that the bottle is closed at the bottom and then taken up, your approach seems viable, but it is difficult to tell exactly without you filling in the details of your computation. A good rule of thumb is that the pressure increases by approximately 1 atmosphere per 10 m of depth.
Thanks for replying. The opening of the bottle is facing up according to the picture. The bottle is not closed at the depth h. However, it is said in the problem statement that the opening of the bottle is very very narrow (so that the air cannot escape).
Related to Measuring the depth of a lake using a bottle
What is the purpose of measuring the depth of a lake using a bottle?
The purpose of measuring the depth of a lake using a bottle is to determine the depth of the water at a specific location. This information can be useful for various purposes such as navigation, determining water levels, and conducting environmental studies.
What materials are needed for measuring the depth of a lake using a bottle?
You will need a plastic bottle with a narrow opening, a weight such as a stone or fishing sinker, a measuring tape or ruler, and a marker or pen to mark the bottle.
How do you measure the depth of a lake using a bottle?
To measure the depth of a lake using a bottle, you will need to first fill the bottle with water and add the weight to the bottom. Lower the bottle into the water until it reaches the bottom, then mark the spot where the water meets the bottle. Next, pull the bottle up and measure the distance between the mark and the opening of the bottle. This measurement will give you the depth of the lake at that location.
Are there any limitations to measuring the depth of a lake using a bottle?
Yes, there are some limitations to this method. The accuracy of the measurement can be affected by factors such as water currents, wind, and the clarity of the water. Additionally, this method may not be suitable for very deep or shallow lakes.
What are the potential benefits of using this method to measure the depth of a lake?
Using a bottle to measure the depth of a lake is a simple and inexpensive method that can be easily done by anyone. It also allows for measurements to be taken at specific locations rather than relying on general depth charts. This method can also be useful for educational purposes and citizen science projects.
