Measuring voltage between your fingers
In summary, a person's left hand is negatively charged and their right hand is positively charged. This seems to be caused by electrochemical reactions taking place between the person's skin and the multimeter leads. The voltages produced by these reactions fluctuate massively and change throughout the day.
mycotheology
89
If I hold one lead of my multimeter to my left index finger, and the other lead to the right index finger, it gives a reading of around 30mV. The reading quickly drops when I leave it there. I tried measuring the voltage between myself and the ground and it read 0mV. Whats stranger is that if I hold the positive lead to my left finger, and the negative lead to my right finger, it gives me a negative reading and vice versa. Its like my left hand is a positive battery terminal and my right hand, a negative terminal. Whats going on here?
I tried dipping my fingers in salt water but that didn't affect the reading. I measured the voltage between my tongue and finger and it gave a lower reading (around 20mV). Measuring between my thumbs gives a higher voltage (around 40mV). Like I said, the voltage starts dropping when I hold it there so the only theory I have right now is that there's negative charge building up in my right arm or hand and then when I apply the voltage to the multimeter. Any idea what the cause of this is? Also, can you try this yourself and tell me whether its the same for you or its just me. I had an operation on my right hand a few years ago and now my right hand gets less blood flow than the left one.
There are electrochemical reactions taking place between the leads and your skin.
That doesn't mean that there really is a voltage between your arms. Well there actually is a voltage that is produced by contracting muscles. Used for ECG. But you can't really measure that with a normal multimeter.
Why do these electrochemical reactions produce a voltage though? Wouldn't electrochemical reactions like that be equal at both areas of contact and thus, produce no overall electrical potential between the two leads? This doesn't explain why the negative charge seems to be in my right hand either. The readings do fluctuate massively for some reason and change throughout the day. Right now the maximum reading I'm getting is 5mV. If I hold the terminals there, they seem to equilibrate at around 2mV. Electrochemical reactions between my skin and the leads can't account for this, I'm more inclined to suspect it has something to do with the blood and/or muscles but you say muscle related voltage can't be detected by a multimeter so it must be something else.
I like a questioning mind. :smile:
Different salt concentrations on your skin; different salts, even, resulting in different
electrochemical half cells. Slightly different metals, different oxide layers. It´s possible, too, that there is an ohmic asymmetry — slight rectifying effect — at some of the metal/metal salt/metal oxide interface, and this could be rectifying a portion of the everpresent mains hum that exists on your body.
The phenomenon you are experiencing is known as "bioelectrical impedance." Our bodies are made up of water and electrolytes, which can conduct electricity. When you touch the multimeter leads with your fingers, your body creates a closed circuit, allowing a small electric current to flow through. The voltage reading you are seeing is the result of this current passing through your body.
The difference in voltage readings between your fingers and your tongue or thumbs could be due to variations in the amount of water and electrolytes present in those areas. This could also explain why the voltage drops when you hold the leads in place for a longer period of time - the current is being drained from your body.
The fact that your left hand is giving a positive reading and your right hand is giving a negative reading could be due to the difference in blood flow between the two hands. Blood contains charged particles, which can affect the electric current flowing through your body.
It is possible that the operation on your right hand has affected the blood flow and electrolyte levels in that hand, leading to a difference in voltage readings compared to your left hand.
To further explore this phenomenon, you could try measuring the voltage between different parts of your body, such as your hands and feet, or between different fingers. You could also try measuring the voltage of other people's fingers to see if there are any differences.
Overall, the cause of the voltage readings you are seeing is likely due to the conductivity of your body and the variations in water and electrolyte levels. It is a normal and natural occurrence and nothing to be concerned about.
FAQ: Measuring voltage between your fingers
What is voltage and how is it measured?
Voltage is the difference in electric potential energy between two points in a circuit. It is measured in units of volts (V) using a voltmeter, which is connected in parallel to the circuit.
How can I measure voltage between my fingers?
To measure voltage between your fingers, you will need a voltmeter and two probes. Place one probe on each finger and read the voltage displayed on the voltmeter. Be sure to follow all safety precautions and consult a professional if needed.
Is it safe to measure voltage between my fingers?
No, it is not safe to measure voltage between your fingers. This can be dangerous and should only be done by trained professionals using proper equipment and safety precautions.
What does the voltage between my fingers indicate?
The voltage between your fingers can indicate the level of static electricity present. This can vary based on environmental factors and can also be influenced by your body's natural conductivity.
Can measuring voltage between my fingers be used for any practical purposes?
Measuring voltage between your fingers is not a reliable or accurate method for any practical purposes. It is mainly used for demonstrations and experiments in educational settings.
