Mech#3 on 1974 AP "C" Exam -- 2 Blocks Connected by a Spring
In summary, the system oscillates for a period of T=2π√M/k when the left-hand block is no longer in contact with the wall.
jgebhardt
A system of two blocks (each of mass M) are connected by a spring with spring constant k. The system is shoved to the left against a wall and the spring is compressed a distance D. The block(s) are then released. Determine the period of oscillation for the system when the left-hand block is no longer in contact with the wall.
T=2π√m/k
So my inclination is to say that T=2π√M/k since I assumed we could consider the oscillation of one individual block to be the same as the other. However, I have the solutions provided by the College Board and they indicate that the mass should be 1/2M resulting in T=2π√M/2k. Can someone explain why the mass is halved?
Hello. Welcome to PF!
What can you say about the motion of the center of mass of the system?
Yes, that's true if you are considering the motion of each mass relative to the center of mass. Except, as one mass moves to the right relative to the CM, then which direction does the other mass move relative to the CM?
If one of the masses changes its distance from the CM by Δx, how much does the spring stretch?
OK, so I get that there are multiple reference perspectives but I'm still unclear as to why that affects T since x is not part of the period equation. I understand that x is involved in finding k but since k is given...If I consider on block to be stationary and the other oscillating with respect to the stationary block I still would have a mass of M oscillating.
I hope I'm not being stupid here but I'm still perplexed. Further assistance?
You don't want to go the reference frame of one of the blocks since the blocks are accelerating and you would have a noninertial reference frame.
However, once the system loses contact with the wall, the CM reference frame is an inertial frame. So, you can analyze the motion of one of the masses in the CM frame. Does Hooke's law apply to each mass? Keep in mind that if the mass on the right moves Δx to the right, then the mass on the left must move -Δx (to the left). So, how much force acts on the mass on the right when it is displaced Δx from its equilibrium position?
Related to Mech#3 on 1974 AP "C" Exam -- 2 Blocks Connected by a Spring
1. What is Mech#3 on the 1974 AP "C" Exam?
Mech#3 is a question on the 1974 AP "C" Exam that deals with two blocks connected by a spring. It involves applying principles of mechanics and solving for the motion of the system.
2. What is the purpose of the question?
The purpose of Mech#3 is to assess a student's understanding of mechanics and their ability to apply concepts to solve a real-world problem.
3. What are the key concepts needed to solve this question?
To solve Mech#3, a student must have a strong understanding of Newton's laws of motion, conservation of energy, and the equations for springs and simple harmonic motion.
4. How do I approach this question?
To approach Mech#3, it is important to carefully read and understand the given information, draw a diagram of the system, and apply the appropriate equations to solve for the unknown quantities.
5. Are there any common mistakes students make when solving this question?
One common mistake students make when solving Mech#3 is not properly setting up the equations or using incorrect values for variables. It is important to double check calculations and use the correct units for all quantities.
