What is the Mechanical Advantage of the Engineer's Machine?
In summary: Normal Force on the BlockIn summary, the maximum weight that the engineer can lift using his machine is twice his own weight. The mechanical advantage of the machine cannot be adjusted and platform 1 can be lowered a maximum of 10 m. The forces upward on the engineer and the mass are 600 N and 1200 N, respectively. In order to solve for the forces, four equations were used: two F = ma equations for the man and the mass, one relating the forces on the man and the mass to each other using energy conservation, and one relating the accelerations to each other using h = 1/2 a T^2. After solving the system of equations, it was determined that the man
lovelyrwwr
48
I've been at this problem for a good hour now and I just can't figure it out :bugeye:
Please help me think through this! It is a very difficult problem in my opinion. Or maybe I'm just missing a fundamental point...Thanks in advance!
An engineer with a mass of 100 kg has designed an ideal mechanical advantage machine below. Platforms 1 and 2 are attached to the machine. When he steps on platform 1, platform 2 rises straight up. The maximum weight that he can lift using his machine in this manner is twice his own. The mechanical advantage of the machine cannot be adjusted. Platform 1 can be lowered a maximum of 10 m.
If the mass m is 100 kg, what are the forces upward on the engineer and the mass m, respectively?
The correct answer is: 600 N, 1200 N.
My thoughts:
So far I understand that because this is a machine, work will be the same, but the force you apply is smaller because you apply it over a greater distance. W = Fd.
Thus, the engineer must "pay the price" for lifting double his weight by applying the force of his weight over twice the distance. Thus, if the force (his weight, 1000 N) is applied for the 10 meters, then he can lift twice his weight (2000 N) to a maximum height of 5 meters.
I also know that the engineer's acceleration is twice as large as the acceleration of the mass.
So my equations for the engineer is as follows:
(MASSman)(gravity) - FN = (MASSMAN)(2a)
And for the mass:
FN - (MASSbox)(gravity) = (MASSbox)a
This is obviously wrong. Some yahoo forum discussing this problem suggested that the normal force the box feels is twice the normal force that the engineer experiences...Is that correct? If so, I don't intuitively understand why that is the case.
hi lovelyrwwr! :smile:
i'm not sure you're understanding the question correctly
if m is 200 kg, then the situation is balanced: the 1000 N weight of the man balances the 2000 N weight of m so the acceleration is zero, and so the upward forces would be equal to the weights
if m is only 100 kg, the weights are as before,
but the upward forces are different (and the accelerations are not zero) …
what are the net forces? what ratio must they be? :wink:
Four equations: two are F = ma for the man and the mass; one relates the forces on the man and the mass to each other (hint: energy conservation); and finally one relates accelerations to each other (hint: h = 1/2 a T^2).
Solve for F1 and F2 (and a1 and a2 if you want).
That part is correct.
That part is incorrect. Acceleration is mass times the NET force on the man and the mass. One is not twice the other. Remember gravity for both sides!
One of the terms there is wrong by a simple factor. Correct that and you will get the answer.
No, it's quite correct.
You don't mean that.
haruspex said:
One of the terms there is wrong by a simple factor. Correct that and you will get the answer.No, it's quite correct.
You're right, I don't.
I meant that, taking the man or the mass individually, each has acceleration equal to the NET force on it divided by his or its mass.
Let 1 = man
2 = mass
After actually looking at the four equations I cited it turns out that a1 = 2 a2 after all, so I missed there, but I saw no a priori reason why that should be so.
One of my sloppier posts, to be sure.
The displacement must be in the ratio 2:1 at all times, and the time elapsed is the same for both, so the speeds and accelerations must also be in the ratio 2:1.
Here is how I got it
Assume the platform with the man is 1.
Assume the platform with the block is 2.
What we know
a1=2a2
N2=2N1 (The mechanic advantage is that the man can lift twice his weight) (Equation A)
N1-m1g=-m1a1 (system with man)
N2-m2g=m2a2 (system with block)
For the man (1)
N1-m1g=-m1a1
N1-100(10)=-(100)a1
N1-1000=-100(2a2) since we know the acceleration of the man must be 2x block
N1-1000=-200a2 (Equation A)
For the system (2)
N2-1000=100a2
2N1-1000=100a2
N1-500=50a2
N1=50a2+500 (Equation B)
Solve Equation A and Equation B System of Equations
Plug Equation B into Equation A
50a2+500-1000=-200a2
-500=-250a2
a2=2
Plug a2 into Equation B
N1=50(2)+500=600N , which is the Normal Force on the Engineer
Plug a2 into Equation A.
N2=2N1
N2=2(600)=1200 N
FAQ: What is the Mechanical Advantage of the Engineer's Machine?
What is a mechanical advantage machine?
A mechanical advantage machine is a device that allows you to apply a smaller force to lift or move a larger object. It can be a simple machine like a lever or a more complex machine like a crane.
How do mechanical advantage machines work?
Mechanical advantage machines work by using the principle of leverage, which allows a smaller force to be applied over a longer distance to produce a larger force over a shorter distance. This is achieved through the use of various components such as wheels, pulleys, levers, and gears.
What is the formula for calculating mechanical advantage?
The formula for mechanical advantage is MA = output force/input force. This means that the mechanical advantage is equal to the ratio of the output force (the force applied by the machine) to the input force (the force applied to the machine).
What are some examples of mechanical advantage machines?
Some common examples of mechanical advantage machines include seesaws, wheelbarrows, scissors, and cranes. Other examples include gears in a bicycle, pulleys in a flagpole, and levers in a crowbar.
What are the advantages of using mechanical advantage machines?
Mechanical advantage machines have several advantages, including the ability to lift or move heavy objects with less effort, the ability to increase speed or distance of movement, and the ability to change the direction of force. They also allow for more precise control and can reduce the risk of injury from lifting heavy objects.
