Mechanical Energy and Frames of Reference
In summary, It is important to take into account the energy of the burnt fuel ejected when observing a spaceship's acceleration from different reference frames. Similarly, when observing a ball rolling down a hill from different reference frames, it is important to consider the energy of the ball and its surroundings to avoid inconsistencies.
CharlesEster6
Hello,
I've come up with a simple, imaginary situation that bugs me. Could someone help resolve my confusion?
Let's say that a spaceship is traveling through space, and two people- observer 1 and observer 2- are watching it. Both observers can monitor the ship's speed and the amount of fuel in its "gas tank." Initially, the ship is moving at speed v with respect to observer 1, and is at rest with respect to observer 2.
Now the spaceship accelerates, so it is moving at speed v with respect to observer 2 and speed 2*v with respect to observer 1. Observer 2 notes that 0.5*m*v2 (m is the mass of the ship) joules of energy are withdrawn from the fuel during this period of acceleration, but to observer 1 it appears that 0.5*m*((2v)2 - v2), or 0.5*m*3v2 joules of energy are consumed. It can't be true that observer 1 records three times more fuel used than observer 2; what accounts for this "inconsistency?"
Thank you!
You need to take into account the energy of the burnt fuel ejected. The energy from burning the fuel goes into ejecting hot gases in one direction and moving the spaceship forward in the other direction in such a way that the total momentum is conserved. If you are careful about taking into account the energy of the gases, there is no inconsistency.
A similar problem is the following:
A ball is stationary at the top of a hill, and someone gives it an infintesimal knock and it rolls down the hill losing potential energy, and gaining kinetic energy until it has final velocity v. (No friction). This sounds sensible.
Now imagine the situation from an observer moving at velocity v. He sees the ball moving away from him, then it rolls down the hill losing potential energy, and eventually comes to rest, losing kinetic energy too! This sounds crazy.
The resolution is along the same lines as your spaceship.
Peter
Hi CharlesEster6 and peteratcam, Welcome to PF,
This is a good question, and peter is correct about the resolution. There is a https://www.physicsforums.com/showthread.php?t=199087" thread about this same subject where the math in the tutorial was discussed in detail.
FAQ: Mechanical Energy and Frames of Reference
What is mechanical energy?
Mechanical energy refers to the energy possessed by an object due to its motion or position. It is a combination of potential energy, which is stored energy, and kinetic energy, which is the energy of motion.
How is mechanical energy calculated?
Mechanical energy is calculated by adding the potential energy and kinetic energy of an object. The formula for mechanical energy is: ME = PE + KE. Potential energy is calculated by multiplying the mass of an object by the force of gravity and its height, while kinetic energy is calculated by multiplying half of the mass by the square of its velocity.
What is a frame of reference?
A frame of reference is the perspective or point of view from which an object's motion is observed. It is used to describe the position, velocity, and acceleration of an object.
How does a frame of reference affect the measurement of mechanical energy?
A frame of reference can affect the measurement of mechanical energy because it can change the observed position, velocity, and acceleration of an object. This, in turn, can alter the calculation of potential and kinetic energy, ultimately affecting the overall measurement of mechanical energy.
What is the difference between a stationary and moving frame of reference?
A stationary frame of reference is a perspective from a fixed point, while a moving frame of reference is a perspective from a point that is in motion. This difference can affect the measurement of mechanical energy as the velocity of the reference point can impact the calculation of kinetic energy.
