Mechanical energy of a pendulum- I just can't get it
In summary, the mechanical energy of a pendulum can be calculated using the equations PE = 1/2 k x^2 and ME = PE at the maximum amplitude point. By finding the constant k from initial data, we can use it to solve for the mechanical energy at a different amplitude. For small amplitudes, the equation PE = kx^2/2 can be used, treating the pendulum as a simple harmonic motion. This method is faster and yields the same result as the geometric approach.
BlueSkyy
34
Mechanical energy of a pendulum- I just can't get it!
A pendulum of length 140 cm swings with an amplitude of 1.9 cm. Its mechanical energy is 5.7 mJ. What is the mechanical energy of the same pendulum when it swings with an amplitude of 3.7 cm?
ME = PE + KE
PE = 1/2 k x^2
PE = mgh
KE = 1/2 m v^2
and I also know that at the top of the arc (amplitude) all of the energy is PE
I keep trying to solve this and always end up with 11.1 mJ - this answer is wrong! I don't know what else to do.
Why do you need to find the KE? Can you find the height difference between the extremities of the pendulum in the two cases?
I think we can just use the equation :
PE = 0.5kx^2
Where k is just a constant, so first we must find k from our initial data :
PE(2)/(x^2) = k
5.7(2)/(1.9^2) = k = 3.158
Now just use this value of k to solve the second part :
PE = 0.5(3.158)(3.7^2)
PE = 21.62 mJ
ME = PE at the max amplitude point, so ME = 21.62 mJ
I think that is right.
Thank you so much Retsam! That worked :D
I didn't know I could use PE = 1/2 k x^2 for pendulums; now I know!
Thank you!
For small amplitudes, you can use PE = kx^2/2. That means, you are essentially treating the simple pendulum as an SHM, in the regime where x is approximately equal to sin x. Geometrically, you would have got the same result, but this is the fastesr way.
FAQ: Mechanical energy of a pendulum- I just can't get it
What is mechanical energy?
Mechanical energy is the sum of potential energy and kinetic energy of an object. Potential energy is the energy an object has due to its position, while kinetic energy is the energy an object has due to its motion.
How does a pendulum have mechanical energy?
A pendulum has mechanical energy because it has both potential and kinetic energy. As the pendulum swings back and forth, it has potential energy at the highest point of its swing and kinetic energy at the lowest point.
How is the mechanical energy of a pendulum calculated?
The mechanical energy of a pendulum can be calculated using the formula E = mgh + 1/2mv², where m is the mass of the pendulum, g is the acceleration due to gravity, h is the height of the pendulum, and v is the velocity of the pendulum.
Can the mechanical energy of a pendulum change?
Yes, the mechanical energy of a pendulum can change due to various factors such as air resistance, friction, and changes in the pendulum's height or velocity.
How does the length of a pendulum affect its mechanical energy?
The length of a pendulum does not affect its mechanical energy. The mass, height, and velocity of the pendulum are the factors that determine its mechanical energy.
