Mechanical energy problem help needed
In summary, we have a car with a mass of 1100 kg traveling down a hill at an angle of 5 degrees to the horizontal. The driver brakes hard and the car skids 15 m. With a coefficient of friction of 0.7 between the tires and the road, we can calculate the initial kinetic energy and speed of the car. To solve this problem, we must use the equations for work done, weight of the car down the hill, normal reaction of the road with the car, and friction force. From there, we can determine the tractive force of the engine before braking and the work done by the brakes against the engine. Finally, using the equations of uniformly accelerated motion, we can solve for the initial
hendrix7
36
A car, of mass 1100 kg, is traveling down a hill, inclined at an angle of 5o to the horizontal. The driver brakes hard and skids 15 m. The coefficient of friction between the tyres and the road is 0.7. Find the initial kinetic energy and speed of the car.
work done = force x displacement
weight of car down the hill = 1100 x 9.8 x sin 5o
normal reaction of road with car = 1100 x 9.8 x cos 5o
friction force = 0.7 x 1100 x 9.8 x cos 5o
I really do not know how to go about solving this. This braking hard and skidding has stumped me.
Hi there,
The skidding just implies that a constant breaking.
Cheers
Hi hendrix7! :smile:
Yes, a car can either roll or skid.
If it rolls, then no energy is lost (the point of contact, of the wheel with the ground, is stationary, so the friction does no work).
Only if it skids is energy lost. :wink:
That's right … just carry on :smile:
tiny-tim
sorry if I appear dumb, but I still don't understand. Does it matter if the car skids forwards or sideways?
oh yes, it does matter …
but I think we can assume that the question means its only skids forwards
(basically, a skidding car is just a block of rubber sliding down the hill! :wink:)
Hi there,
In the idea, I would say it does not matter which way the car slide. As long as the coefficient is considered to be the same.
Cheers
Okay, here is my attempt at a solution. I would welcome any input from you guys as to whether my method is sound.
Firstly, I have to assume that the car was traveling at constant speed before the braking so that I can then calculate the tractive force of the engine:
weight of car down the hill + tractive force = friction with road
Reaction with road = 1100 x 9.8 cos 5o = 10,739 N
Weight of car down the hill = 1100 x 9.8 x sin 5o = 939.5 N
939.5 + tractive force = 0.7 x 10,739 = 7,517.3
so the tractive force of the engine before braking = 7,517.3 - 939.5 = 6577.8 N
When the car begins to skid, there is no friction between the car and the road. The only forces acting on the car are the braking friction and the weight of the car. Therefore, the work done by the brakes against the engine must be 6577.8 x 15 = 98,667 j and this must be the k.e. of the car before the brakes were applied.
1/2 x 1100 x v2 = 98,667
v = 13.4 m s-1
Hi there,
Why don't you start from the start and use Newton's second law correctly:[tex]\sum \vec{F} = m\vec{a}[/tex]
From there, which forces are acting on your vehicle. From these forces, you can determine the acceleration ([tex]\pm[/tex]) of the car.
Assuming a constant acceleration, you can apply the simple equations of a uniformly accelerated motion. And there you go, you have your solutions.
Hint: don't forget that you have two dimensional vectors here.
Sorry to revive a dead thread, but I'm currently looking at this problem and am just wondering why the weight of the car down the hill is
First analyze the units. The car is 1100 kg. Acceleration due to gravity is 9.8 m/s^2. Force is in Newtons, which is kg m/s^2 (check this using F = ma). So the units are correct.
The sin 5° comes about because gravity acts straight down. You can split this F into two components -- downhill and into (normal to) the hill -- which are just F sin 5° and F cos 5°. You can remind yourself which is which by thinking of a "flat" hill, where all the force due to gravity is "into" the hill and none is "downhill." Since sin 0° = 0 and cos 0° = 1, the sin must be downhill and the cos must be into the hill.
Hence the original problem, which is the "weight" (gravity force) of the car down the hill:
1100 kg * 9.8 m/s^2 * sin 5°.
FAQ: Mechanical energy problem help needed
What is mechanical energy?
Mechanical energy is the energy possessed by an object due to its motion or position. It is a combination of kinetic energy (energy of motion) and potential energy (energy of position).
How do you solve mechanical energy problems?
To solve mechanical energy problems, you need to identify the types of energy involved, determine their initial and final values, and use the principle of conservation of energy to set up an equation and solve for the unknown quantity.
What is the principle of conservation of energy?
The principle of conservation of energy states that energy cannot be created or destroyed, only transformed from one form to another. In mechanical energy problems, this means that the total amount of mechanical energy (kinetic + potential) remains constant.
What are some common types of mechanical energy problems?
Some common types of mechanical energy problems include finding the speed or height of an object at a given position, calculating the work done by a force on an object, and determining the efficiency of a machine.
What are some useful equations for solving mechanical energy problems?
Some useful equations for solving mechanical energy problems include:
  • Kinetic energy (KE) = 1/2 x mass x velocity^2
  • Potential energy (PE) = mass x gravity x height
  • Work (W) = force x distance
  • Power (P) = work/time
