Mechanical engineering - Cam Laws - Ct Accel.
In summary, the student is trying to find the laws for the displacement, velocity and acceleration for a cam with constant acceleration, but is having difficulty finding them. The student is also trying to find the inverse of the displacement, velocity and acceleration for the cam, but is having difficulty doing so.
sicro
1. Homework Statement
If you could please tell me the "fall" laws for displacement, velocity and acceleration for a cam with constant acceleration.
3. The Attempt at a Solution
Could only manage to find the laws for the rising part, in a 1996 book.
Didnt find the laws on google either. Just mentions of the existence of the constant acceleration motion law.
The fall is opposite to the rise, but I don't know how to "mirror" the laws.
For ex: Displacement: Xe= (Xemax/((1-ki)*(Xi)1^2))*(-ki*(Xi)1^2+2*(Xi)1*Xi-Xi^2)
Xe=movement[rad], Xemax=max value for Xe [rad], Xi=current angle of rotation [rad], Xi1=total angle of rotation for rise/dwell or fall. (in this case Rise), k1=point where the "bend" of the curve-in the chart- changes- in my case it is Xemax/2;
So, to reverse that, I don't know what I must do...
Thank you! And I am sorry if my English isn't very good.. I am from Eastern Europe.
This can definitely be tricky. What you need to do is to ask yourself what is the role of each of the variables in this expression, and then find comparable expressions in the new situation.
One of those variables was the distance from the beginning of the event to the current point. How will that value be described for the return (falling) curve? Another of those variables is the event length, the total angle turned during the motion. How is that to be expressed for the return (falling) motion?
Once you have identified these new expressions, then try to put together the equivalent functional forms that will describe the motion. If possible, use a computer to evaluate your expression and plot the motion, both rising and falling, and see if things look right. If things look correct for several arbitrary choices of the parameters, then there is a pretty good chance that you have worked it out correctly.
Thank you, Ill try to do that...
sicro: I might not understand, but I can think of different ways to reverse the equation you posted. See if any of these are what you want for reversed displacement.
(1) Xe = Xemax*[-ki*Xi1^2 + 2*Xi1*(Xemax - Xi) - (Xemax - Xi)^2]/[(1 - ki)*Xi1^2].
(2) Xe = {-Xemax*[-ki*Xi1^2 + 2*Xi1*(Xemax - Xi) - (Xemax - Xi)^2]/[(1 - ki)*Xi1^2]} + 2*Xemax.
(3) Xe = {-Xemax*(-ki*Xi1^2 + 2*Xi1*Xi - Xi^2)/[(1 - ki)*Xi1^2]} + 2*Xemax.
Ok, i did it by mirroring the chart on paper. Wasnt that precise, but it worked.
Thank you all for your time and I am sorry for the disturbance..
It is not disturbance, sicro, but you must realize that simply drawing the graph will not get the job done with sufficient accuracy to be useful. You really must learn to manipulate the functions if you are going to master this material.
Yes I know, but I didnt have anymore time left.. :(
Related to Mechanical engineering - Cam Laws - Ct Accel.
1. What is mechanical engineering?
Mechanical engineering is a branch of engineering that involves the design, analysis, and production of mechanical systems. It applies principles of physics, materials science, and mathematics to create, maintain, and improve machines and devices used in various industries.
2. What are Cam Laws?
Cam laws are mathematical formulas that describe the motion of a cam, which is a mechanical component used to convert rotational motion into linear motion. These laws help engineers design and analyze cams for various applications, such as in engines and manufacturing equipment.
3. How do Cam Laws relate to Ct Accel.?
Cam laws are used to determine the acceleration of a cam, which is important in understanding its performance and efficiency. Ct Accel. stands for "cam-to-acceleration ratio" and is a measure of how well a cam can convert rotational motion into linear motion.
4. What factors affect Cam Laws?
The shape and size of the cam, as well as the speed and direction of rotation, can affect the cam laws. Other factors such as the materials used, friction, and wear also play a role in the performance of a cam and its adherence to the cam laws.
5. How are Cam Laws used in practical applications?
Cam laws are used in the design and optimization of cams for various applications, such as in engines, pumps, and manufacturing equipment. They help engineers determine the best cam shape and size to achieve the desired motion and performance, while also considering factors such as efficiency and durability.
  • Mechanical Engineering
  • Classical Physics
