Mechanical Engineering Dynamics Problem
In summary, the problem involves a plastic film moving over two drums, with the speed of the tape increasing uniformly from v0=2ft/s to v1=4ft/s over a 4s interval. The goal is to determine the angular acceleration of drum B and the number of revolutions executed by drum B during the 4s interval. However, the attempt at a solution provided may not be entirely accurate due to differences in linear and angular acceleration, inconsistent units, or a possible error in the back of the book's solution. It is recommended to double-check the calculations or consult with a reliable source for confirmation.
Tribean
A plastic film moves over two drums. During a 4s interval the speed of the tape is increased uniformly from v0= 2ft/s to v1= 4ft/s. Knowing that the tape does not slip on the drums, determine (a) the angular acceleration of drum B, (b) the number of revolutions executed by drum B during the 4s interval.
diagram of problemhttp://www.chegg.com/homework-help/questions-and-answers/plastic-film-moves-drums-4s-interval-speed-tape-increased-uniformly-v0-2ft-s-v1-4ft-s-know-q3878687
[itex]v^{2}_{f}[/itex]=v[itex]^{2}_{0}[/itex]+at
v=r[itex]\omega[/itex]
a[itex]_{t}[/itex]=r[itex]\alpha[/itex]
I used the first equation to find that the linear acceleration of the tape is 3 ft/s^2. Since it's translating to drum B I would assume that the point that it touches the top of drum B would also have a linear acceleration of 3 ft/s^2 I then used my 2nd equation to figure out the angular acceleration of B by taking its radius of 15 in or 1.25 ft and dividing it from the linear acceleration coming up with 2.4 rad/s^2 but the back of the book states .400 rad/s^2
Where am I going wrong?
Hello,
Thank you for posting your problem and your attempted solution. Based on your equations and calculations, it seems like you are on the right track. However, there are a few things that may have caused you to get a different answer than the one given in the back of the book.
First, it is important to note that the angular acceleration of drum B will be different from the linear acceleration of the tape. This is because the tape is moving linearly, while the drum is rotating. Therefore, the equations you have used may not be directly applicable to finding the angular acceleration of the drum.
Secondly, it is not clear what units you used for your calculations. In your equations, you have used both ft/s and ft/s^2, which may cause confusion. It is important to use consistent units throughout your calculations to avoid errors.
Finally, it is possible that the back of the book has made a mistake in their calculation. Sometimes, textbooks and answer keys may contain errors. If you are confident in your approach and calculations, it may be worth double-checking with your professor or other reliable sources to confirm the correct answer.
I hope this helps clarify your understanding of the problem. Keep up the good work!
Related to Mechanical Engineering Dynamics Problem
What is Mechanical Engineering Dynamics?
Mechanical Engineering Dynamics is a branch of mechanical engineering that deals with the study of motion and the forces that cause motion. It is concerned with the analysis and design of systems that involve moving parts and how they interact with their environment.
What are some examples of Mechanical Engineering Dynamics problems?
Some examples of Mechanical Engineering Dynamics problems include calculating the forces on a car's suspension system, determining the motion of a pendulum, and analyzing the stresses on a rotating turbine blade.
What are the key principles in solving Mechanical Engineering Dynamics problems?
The key principles in solving Mechanical Engineering Dynamics problems include understanding Newton's Laws of Motion, conservation of energy and momentum, and the use of free body diagrams and equations of motion.
What tools are commonly used in solving Mechanical Engineering Dynamics problems?
Some commonly used tools in solving Mechanical Engineering Dynamics problems include computer-aided design (CAD) software, simulation programs, and physical models such as prototypes or scale models.
How is Mechanical Engineering Dynamics used in real-world applications?
Mechanical Engineering Dynamics is used in various real-world applications such as designing and analyzing mechanical systems in industries like automotive, aerospace, and robotics. It is also used in the development of new technologies and products.
  • Aerospace Engineering
  • STEM Academic Advising
