Mechanical engineering help with fluids
In summary, the shear rate and apparent viscosity for the first question are 4.9 s-1 and 1.12 Pa s, respectively. For the second question, the torque required to overcome viscous resistance is 2262.19 Nm and the power loss is 42,604.34 W.
apamnani1
Hi people!
I have been doing some fluid questions and got stuck ont he following two;
1) A Casson plastic fluid is subjected to a shear force of 5.5 Pa. If the fluid obeys a law of the form T =1.5 +0.2^0.45u, determine the shear rate and apparent viscosity under these conditions
2) Oil of dynamic viscosity 0.12 Nsm-2 is used to lubricate the space between the plain journal bearing with the shaft. The shaft and bearing are concentric and the space between them is filled with an oil of dynamic viscosity of 0.15Nsm^-2.
Determine the torque required to overcome viscous resistance and the power loss when the shaft is rotating at a speed of 3000rpm.
Any help would be amazing!
Cheers
, Kev.For the first question, the shear rate can be calculated using the equation u = (T - 1.5)/0.2^0.45, where T is the shear stress (5.5 Pa). Thus, the shear rate is equal to 4.9 s-1. The apparent viscosity can then be calculated using the equation η_a = T/u, where η_a is the apparent viscosity and u is the shear rate (4.9 s-1). Therefore, the apparent viscosity is equal to 1.12 Pa s. For the second question, the torque required to overcome viscous resistance can be calculated using the equation T = 2πnηL, where n is the rotational speed (3000 rpm), η is the dynamic viscosity of the oil (0.12 Nsm-2), and L is the length of the shaft in m. The power loss can then be calculated using the equation P = Tω, where P is the power loss, T is the torque, and ω is the angular velocity (ω = 2πn = 18,849.36 rad/s).
Related to Mechanical engineering help with fluids
1. What is the role of fluids in mechanical engineering?
Fluids play a crucial role in mechanical engineering as they are used to power and control various systems and machinery. They are also essential for heat transfer and lubrication in machines.
2. What are some common applications of fluid mechanics in mechanical engineering?
Fluid mechanics is used in a wide range of applications in mechanical engineering, including designing pumps, turbines, and compressors, as well as analyzing the flow of fluids in pipes and channels.
3. How do I calculate pressure and flow rate in a fluid system?
To calculate pressure and flow rate in a fluid system, you can use Bernoulli's equation, which takes into account factors such as fluid density, velocity, and height. Another approach is to use the continuity equation, which states that the mass flow rate into a system must equal the mass flow rate out.
4. Can you recommend any resources for learning more about fluid mechanics in mechanical engineering?
There are many excellent resources available for learning about fluid mechanics in mechanical engineering. Some popular textbooks include "Fundamentals of Fluid Mechanics" by Bruce R. Munson and "Introduction to Fluid Mechanics" by Robert W. Fox. Online resources such as MIT OpenCourseWare also offer free lectures and course materials on the subject.
5. How can I apply my knowledge of fluid mechanics to real-world engineering problems?
To apply your knowledge of fluid mechanics to real-world engineering problems, it is important to have a strong understanding of the fundamental principles and equations. Additionally, hands-on experience through internships or research projects can help you develop practical skills in applying fluid mechanics to solve engineering problems.
  • STEM Academic Advising
  • Other Physics Topics
